Old    David (tparider)      Join Date: Aug 2003       04-19-2010, 8:21 AM Reply
Anyone know? Engine is a 340 Monsoon on a 2005 Wakesetter 23LSV.
Thanks...
Old    David (tparider)      Join Date: Aug 2003       04-19-2010, 1:34 PM Reply
anyone?
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-19-2010, 1:36 PM Reply
i would say 55-65 amps
i have too look it up
Old    Cory McLean (kikitlo)      Join Date: Jul 2005       04-19-2010, 1:41 PM Reply
I would have to say that it is a 90amp alt. I have an 07 so I don't think they changed it in that time frame. It looks as though the manuals for motors are either 94-02 or 03-present.
http://www.indmar.com/ProductLine/Ma...340/index.html
Old    David (tparider)      Join Date: Aug 2003       04-19-2010, 1:48 PM Reply
90 amp? Wow, that's pretty stout.
I just found this online but it says it's for a 2007 (like yours Cory).
General Specifications
Displacement: 5.7L / 350 CID
Cylinders: V-8
Bore & Stroke: 4.00 x 3.48
Compression Ratio: 9.4:1 (High-flow Vortec heads)
Exhaust: ETX/CAT (Extreme Tuned Exhaust with Catalyst).
Fuel System: Multi-port electric fuel injection (MPFI)
ECM: Delphi MEFI-5 hardware/software system that is custom calibrated by Indmar.
Ignition: HVS High Voltage Switch Ignition System
Fuel Required: Unleaded, 89-octane minimum.
Oil Type: Pennzoil Marine (SAE 15W-40), service SJ/CG4
Oil Capacity: 5.5 quarts with filter
Oil Filter: Pennzoil PZ3
Spark Pugs: 41-993 (Platinum Tip)
Max. RPM: 5,200
Old    Chad (dcwillette)      Join Date: Sep 2005       04-19-2010, 4:10 PM Reply
It's 90 amps
