Old    Chris (ccripps)      Join Date: Oct 2003       04-18-2010, 3:15 PM Reply
Is there a Filter that needs to be Changed on a V-drive Transmision??
My Manual for Mercruiser says change transmision fluid and fliter, but I can find one.
Thanks for any help
Chris
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       04-18-2010, 7:31 PM Reply
No v-drive filter that I am aware of, but if the manual states it does does it give any more info? Location? Type?
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-19-2010, 12:35 PM Reply
transmissions have a filter
the hurth zf has a screen, you can pull and clean
the borg warners has a screen, but never needs a cleaning unless you pull the tranny out
Old    Chris (ccripps)      Join Date: Oct 2003       04-20-2010, 7:07 AM Reply
Mine is a Velvet drive, So does that mean no filter or screeen to be changed
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-20-2010, 12:53 PM Reply
Velvet has a screen, but no need to clean it, because you need to pull it to clean it
Old    S Dub (sdub)      Join Date: Jan 2003       04-20-2010, 1:28 PM Reply
hurth has a screen, but does anybody actually clean it? I would like to know if anybody or any dealer actually cleans the screen. I know its recomended, but I dont think anybody actually does it.
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-20-2010, 1:40 PM Reply
I do
i have seen metal flakes on that screen all the time
no most dealers do not do anything, to tell you the truth
and most do not winterize properly also
Old    S Dub (sdub)      Join Date: Jan 2003       04-20-2010, 3:23 PM Reply
have you ever had any problems with the plate that covers the filter leaking after removing for the first time?
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       04-20-2010, 5:58 PM Reply
nope, you need to push it down on the o-ring
it spins off
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       04-20-2010, 6:05 PM Reply
Just an FYI, the ZF and Hurth drop centers are now recommended to run SAE 30 instead of ATF when placed in commercial duty. A ton of ballast would qualify. Check with ZF or Transmission Marine regarding your serial number for application. They are much happier with 30 and it eliminates that backlash chatter.
