Old    Adam (woz)      Join Date: Feb 2009       04-14-2010, 6:42 PM Reply
whats the best way to fix this? i was thinking, pick away all the little pieces till its smooth. then fill it with epoxy. anybody got a better idea?
Old    Andrew Moreton (andrew_moreton)      Join Date: Feb 2003       04-14-2010, 6:57 PM Reply
Buy this Sun Cure kit for $8.95 off Amazon.
I had an edge problem last week so I bought this, it arrived a few days later, and now my edge is as good as new. But yes, you'll want to sand all that down, fill with epoxy, place in the sun until firm, and then resand so that the edge is the same shape as the original.
Old    C.I.E..... Evan (guido)      Join Date: Jul 2002       04-14-2010, 7:14 PM Reply
I usually use fiberglass resin to repair the edges of my boards.
Sand it down a bit, clean up the loose bits. Set the board upside down, put some painters tape on the rounded edge of the board with about 1/2" over laying the edge. Fill the gap with resin/hardener. Allow to dry, peel the tape and shape with some sand paper, file, or a dremel tool. It'll be good as new in no-time.
Old    Adam (woz)      Join Date: Feb 2009       04-15-2010, 4:00 PM Reply
thanks, i found out sun cure makes a wakeboard repair kit, and its exactly for this damage. $11 not bad.
