Old    CONSIGLIEREG8R (consigliereg8r)      Join Date: Aug 2009       04-14-2010, 7:43 PM Reply
I got my boat back from the pre-season tune up. My prop was bent again. He said it happened while the motor was in reverse. The mechanic said he preferred OJ props to the Acme props that came standard. ( I may have that backwards) He showed me my factory prop and an OJ. The OJ was much thicker on the tips. I ordered an OJ to use as the main prop and will bet the Acme tuned up again. Any thoughts?
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       04-14-2010, 8:43 PM Reply
Its my understanding that the Acme's are thinner than the OJ's. My prop guy told me this.
Old    CONSIGLIEREG8R (consigliereg8r)      Join Date: Aug 2009       04-14-2010, 8:49 PM Reply
I hope the OJ is more durable. The ACME when perfectly pitched and tuned would likely give better performance, but it seems hard to keep tuned.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       04-14-2010, 9:25 PM Reply
Ive never had my Acme's get out of tune without some sort of impact. That being said, my experience is it takes less to knock an Acme out of whack, than an OJ. Its a balance between weight and strength.
Old    CONSIGLIEREG8R (consigliereg8r)      Join Date: Aug 2009       04-16-2010, 5:57 AM Reply
the bend is slight. One outer edge tip; is bent a little toward the bow instead of the the stern. He said the vibration would take it's toll over time. Like I said. I am getting an OJ and fixing the ACME for a spare.
The mechanic said it was likely done when backing out from the beach and caused by sand.
Old    Jason (corerider)      Join Date: May 2008       04-16-2010, 7:11 AM Reply
Just my $0.02, but I prefer ACME over OJ just becasue the ACME will bend. If you do hit something of any real size the ACME, being made of brass, it will bend and take the damage where as the OJ, since it's made of stainless steel might transfer more shock and damage to other potential weak points in the drivetrain. Would you rather replace a $400-500 prop, or spend several thousand to replace prop, prop shaft, v-drive, etc.? That's just my take on it.
I had some damage to my prop last season while hitting a stick when backing off the trailer. It only bent the tip of one blade, but it made a lot of vibration. I took a pair of channel locks and bent most of the damage out and rode the rest of the day. I couldn't have done that with an OJ I bet.
Old    Bawshogg (bawshogg)      Join Date: Dec 2005       04-16-2010, 7:40 AM Reply
OJ makes ni-bril,(brass) props too. I actyally don't think thyey make stainless inboard props anymore, or haven't for a while for that reason.
Old    Big Nate (thesack)      Join Date: Mar 2008       04-16-2010, 8:54 AM Reply
Just curious, because I do vibration analysis for a living, did you ever feel/hear an increase in vibration in the boat last year?
Old    CONSIGLIEREG8R (consigliereg8r)      Join Date: Aug 2009       04-16-2010, 12:49 PM Reply
The OJ prop I am getting is brass/bronze. It is not stainless. I can't tell any difference in the vibration. The guy is a former CC corporate engine guy and really knows is stuff. He has his own shop and my dealer said take my boat to him. I live 350 miles from my dealer.
