Old     (gtrcs)      Join Date: Apr 2010       04-06-2010, 5:01 PM Reply
Hi guys interested in the MB sports, how do the 220 V and the B-52(smaller one compare)?
thanks in adance guys
Old     (wakereviews)      Join Date: Sep 2006       04-06-2010, 5:13 PM Reply
It's the exact same boat, just different gel and standard options.
Old     (alans)      Join Date: Aug 2005       04-06-2010, 5:49 PM Reply
Yep. What years are you looking at?
Old     (gtrcs)      Join Date: Apr 2010       04-06-2010, 6:47 PM Reply
Thanks Ian.
Hi Alan, I was thinking 05, I have heard they are better from 04 and newer although I dont know how true this is.
Old     (jyoungusa)      Join Date: Sep 2009       04-07-2010, 4:58 AM Reply
I have an 08 220V with most of the standard options that a B52 has except sub-woofer - great boat. In a lot of cases the difference is the styling/scheme in the gel coat - classic lines vs tribal pattern. My 08 has a 45 gal tank, 343HP PCM, 1800lbs of pumped ballast (wish MB had introduced the Pure Vert System as year earlier). There can be differences in the Skylon Towers - how they fold down / design on board racks etc...
Old     (alans)      Join Date: Aug 2005       04-07-2010, 6:31 AM Reply
The '08 has about 3" taller free-board, shorter engine hatch, better ballast pumps, a mild engine upgrade, different tower, and different rear hull design from the '05. There are basically rolling changes every year from '04 to '10 on that boat.
Old     (gtrcs)      Join Date: Apr 2010       04-07-2010, 4:26 PM Reply
So the '05 is the same bottom as the '09
Old     (alans)      Join Date: Aug 2005       04-07-2010, 5:26 PM Reply
95%. The newest version has "built in trim tabs." At least that is the easiest way to describe it.
Old     (gtrcs)      Join Date: Apr 2010       04-07-2010, 6:18 PM Reply
Thanks Alan, your info shoulkd help me alot.
Old     (motorcitymatt)      Join Date: Feb 2007       04-07-2010, 7:25 PM Reply
"Built in trim tabs"............. HUH???? Please explain.
Thanks
Old     (alans)      Join Date: Aug 2005       04-07-2010, 8:23 PM Reply
Here is a little rundown of what is different from '03 to '08.
Old     (alans)      Join Date: Aug 2005       04-07-2010, 8:47 PM Reply
I am such a nerd
Old     (ponyh8r)      Join Date: Dec 2004       04-08-2010, 2:27 AM Reply
Haha..nice work Alan. Mike should consider giving you a job.
Old     (alans)      Join Date: Aug 2005       04-08-2010, 5:38 AM Reply
I would do it in a heartbeat, unfortunately i need to make money, Not so easy to do in the boat business, believe me, I have tried.
Old     (mdaijogo)      Join Date: Mar 2010       04-08-2010, 9:59 AM Reply
Alan-
This built in trim tab is not present in my 09 Tomcat. Is this "feature" only on the 220V?
Mario-
Old     (alans)      Join Date: Aug 2005       04-08-2010, 10:58 AM Reply
Specific to the 220V. It is not really a "trim tab", but it does have a slight bit of "hook" in it. No your 09 Tomcat does not have it. It was really just a mild redesign to assist the boat in getting on plane faster. It also gives the stern a little extra "lift" at higher speeds, which actually make the 22'er a decent slalom boat at speeds over 30 mph.
Old     (moon)      Join Date: Oct 2008       04-08-2010, 11:34 AM Reply
We have an 03 220V and for a first time boat owner I'd have to say I'm pretty pleased with it. I'm not really sure how the 05 is any different then the 03, Alan could you give me a little run down?
Moon
Old     (alans)      Join Date: Aug 2005       04-08-2010, 12:13 PM Reply
As far as I can remember, the only differences between 03 and 05 is that the spray pockets are removed. Oh and I think the ballast pump system was re-engineered.
Old     (moon)      Join Date: Oct 2008       04-08-2010, 1:31 PM Reply
Why does my 03 have spray pockets and newer models don't? What was the purpose of the spray pocket?
Thanks,
Moon
Old     (wakeborder5)      Join Date: Jun 2002       04-08-2010, 5:28 PM Reply
I don't know what exactly the purpose of spray pockets were, but they have been noted for causing spray that washes out the wake I believe.
Old     (alans)      Join Date: Aug 2005       04-08-2010, 7:10 PM Reply
They definitely cause a bit of a notch in the wakeboard wake. What is interesting to me is that the best hulls from MC and CC have them.
Old     (gtrcs)      Join Date: Apr 2010       04-08-2010, 10:50 PM Reply
what yr model has this hook Alan? as we dont mind the ski now and then.
Is the '02 the same bottom other than the splash pockets being taken away?
Old     (alans)      Join Date: Aug 2005       04-09-2010, 3:35 AM Reply
2007 was the first year that has the extended hull surface.
2004 was the first year that the spray pockets were eliminated
Old     (gtrcs)      Join Date: Apr 2010       04-09-2010, 5:34 AM Reply
so would you reccomend the '07 and later for the ski wake?
Old     (alans)      Join Date: Aug 2005       04-09-2010, 6:09 AM Reply
Most of the skiers that I took out in the '07 and later were very impressed with the wake at slalom speeds, for a 22' v-drive. No, I can't comment on pre-'07 or pre-'04 because I just can't remember.
For anyone else reading this thread, everything above only pertains to the 220 or B-52 hull. Not the 230v, B-52 V23, B-52v 21 TWB, F21 Tomcat, or F23 Tomcat.
