Old    E (22vdrive)      Join Date: Apr 2010       04-06-2010, 8:55 PM Reply
I'm having problems with my spedometers on my boat. The speed they are showing is way off. Does anyone know how I could calibrate them to be more true?
Old    Tony (supraride)      Join Date: Jun 2007       04-06-2010, 10:42 PM Reply
There should be a little dial under the dash on the left side that you can calibrate it with. Its small so you may need to get under there to see it. Good luck
Old    E (22vdrive)      Join Date: Apr 2010       04-06-2010, 11:23 PM Reply
Thanks for the tip!
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       04-07-2010, 7:12 AM Reply
Tony is correct. You will somtimes unknowingly bump this dial. IT knock the speedo off.
Old    Steven Spotts (sp0tts)      Join Date: Jun 2004       04-07-2010, 8:59 AM Reply
If I remember correctly the little dial on the 04's is actually on the right, but basically, with a GPS and that dial you can calibrate. If it's way off, it may be time for a new paddle wheel.
