Old    Zach Lear (zleartsu)      Join Date: Mar 2004       04-12-2010, 12:30 PM Reply
what is the best way to run 6 speakers off of a kicker 700.5?
i
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-12-2010, 12:43 PM Reply
If they are all 4 ohm speakers: 1 pair on chnl 1 and 2, 1 pair wired parallel (+ to +/- to -) on chnl 3 and 3rd pair same way on chnl 4
Old    Zach Lear (zleartsu)      Join Date: Mar 2004       04-12-2010, 12:46 PM Reply
sorry should said they are the polk db651
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-12-2010, 12:46 PM Reply
If they are all 4 ohm speakers: 1 pair on chnls 1 and 2, 2nd pair wired parallel (+to+/-to-) on chnl 3, 3rd pair same way on chnl 4.
EDIT: the Db's are 4 ohm.
Old    Zach Lear (zleartsu)      Join Date: Mar 2004       04-12-2010, 12:52 PM Reply
So I need three sets of wires running up my tower instead of the two I have now.
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-12-2010, 1:52 PM Reply
If all 6 are going on the tower, then you will need 4 speaker wire pairs - one for speaker 1, one for speaker 2, one for speakers 3/4 and one for speakers 5/6. You have a 4 chnl amp and all 4 chnls will be used.
Old    Bawshogg (bawshogg)      Join Date: Dec 2005       04-12-2010, 2:00 PM Reply
Well, If they are all on the tower, you will need 4 wire runs total. Two for the two speakers running at 4 ohm and two for the other 4 speakers running at 2 ohm. Or can wire them in a series/parallel seaquence that will net you around 2.6 ohms. You would need to wire 2 of the speakers in series and the third in parallel. That way you would only need to use one wire run per side up the tower.
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-12-2010, 4:16 PM Reply
Although this method will work, it only utilizes 2 of the 4 chnls, and each speaker will only net about 30 watts rms each. IMP, it would be better to leave off one pair and then wire the other 2 pair one speaker p/chnl and then the 4 get 70 watts each.
Old    Bawshogg (bawshogg)      Join Date: Dec 2005       04-12-2010, 5:25 PM Reply
Very true, just giving all the possible options, seems like he didn't wanna run the extra wires? I dunno. Me personally, I wouldn't waist my time only running even 70 per driver to a tower speaker. Unless it was for looks mostly I guess. I would most likely look for a bigger amp. but I understand sometimes budget dictates.
Old    Dax Jolly (volzalum)      Join Date: May 2009       04-12-2010, 5:41 PM Reply
If you search on the internet now you can find the Alpine PDX-2.150 for less than 200 new (~190) and the PDX-4.150 for less than 400 new (~340) ... that is total shipped price.
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-12-2010, 6:10 PM Reply
The Alpine 2chnl would only net him 50 watts rms to each speaker, not a lot of increase for the cost of an additional amp since it looks like he already owns the 700.5. IMO, a 2chnl that would do 250 watts RMS x 2 @ 2ohm IS the best way to go for what you want to do, but the PDX 2.150 is not enough amp and neither is using 2 chnls of the 700.5.
The 4.150 would be the same power to each speaker if the parallel/series 2.6 config was used using only 2 chnls and IMO, 150 watts to each speaker @ 4 ohm is too much for the DB's.
Old    Zach Lear (zleartsu)      Join Date: Mar 2004       04-13-2010, 6:56 AM Reply
thanks for the info guys. I going to play around with them tonight and see what works the best.
