Old    Andy Graham (ottog1979)      Join Date: Apr 2007       03-31-2010, 2:20 PM Reply
I'm ordering some Silver Cloud (off-white) gel coat from Gel Coat Products in Seattle to fix a few hull dings. An option is to get (or not) wax mixed into the gel coat. Apparently, this helps the gel coat dry without necessarily covering it with the Mylar plastic. Not very sure about this, though.
Do I need or should I get wax in the gel coat or not?
Old    Bawshogg (bawshogg)      Join Date: Dec 2005       03-31-2010, 8:19 PM Reply
I would. Done it both ways, if you are just doing a small areas the wax makes it alot easier to use. It's like filling holes in drywall. and no fuss to get it to dry.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       03-31-2010, 9:03 PM Reply
Use no-wax in a female mold to leave a tacky surface needed to add lamination layers. Add wax for exterior finish work it leaves a smooth hard surface.
Old    Andy Graham (ottog1979)      Join Date: Apr 2007       03-31-2010, 9:49 PM Reply
Perfect! Thanks, guys.
