Old    Mario (mdaijogo)      Join Date: Mar 2010       03-29-2010, 12:46 PM Reply
With the new F21, I need to adjust the Fulton F2 jack for a higher clearance. I took this picture from "G" (grant_west) post of the F2.
I loosened this torx bolt but the mount does not move up or down. Is there anything else I need to loosen before the mount can move?
Thanks.
Mario-
Old    pip (pip9ball)      Join Date: Sep 2009       03-29-2010, 8:03 PM Reply
Let me know if you figure it out...I've been trying to do the same on my TWB
Old    Brady (pdxWAKE.com) (big_b_21v)      Join Date: Oct 2006       03-29-2010, 9:55 PM Reply
You have to loosen the bolt inside of the mounting plate too. Then slide the whole mechanism on the jack.
We had the same problem with the new F2 not going high enough. Works great now.
Old    Mario (mdaijogo)      Join Date: Mar 2010       03-31-2010, 9:07 PM Reply
Thanks Brady for the info. Here is what I needed to do to adjust my F2 jack.
Patient prep:
Using a 9/16" socket, I removed the 4 mounting bolts and washers from the trailer/F2.
You can see here the 3/4" nut on the backside of the jack. This nut along with the 7mm allen head bolt need to be loosened to make any height adjustments to the F2.
I made sure to mark my original height.
Then I marked 3" from that mark for the new setting.
I tightened the 3/4" nut and then the 7mm allen head. From there, I bolted up the 4 9/16" washer/bolt combination back to the trailer.
Adjustment done.
Mario-
Old    pip (pip9ball)      Join Date: Sep 2009       03-31-2010, 11:51 PM Reply
Mario,
Is the Blue line the new position where you moved the mount to? In other words, you slide the mount up to increase range?
-Phillip
Old    pip (pip9ball)      Join Date: Sep 2009       03-31-2010, 11:56 PM Reply
Also, this will reduce the amount you can lower the tongue by the amount you moved, correct?
I might have to measure my garage to see how much clearance I have :-)
Old    Mario (mdaijogo)      Join Date: Mar 2010       04-01-2010, 10:16 AM Reply
Pip-
The blue mark is the new position I moved the jack too. This will give me a higher starting point when I use the jack. This will reduce the amount you can lower the tongue by. In this case it would be 3 inches higher start, 3 inches of reduce lower limit.
Mario-
Old    Matt Laird (Matt)      Join Date: Mar 2010       05-07-2010, 9:15 AM Reply
I even used a 1/2" drive impact and can't break the 7mm bolt... Any suggestions
