Old    Andrew"Jet"Mitchell (andrewjet)      Join Date: Jan 2003       05-17-2010, 10:11 PM Reply
What am I doing wrong or what can I work on?? I didn't hit it very hard, trying to get my basics back. Boards not level? Not making it across? 21 mph, 2-sections off 80', SSV 70% filled? Thanks Jet
http://www.facebook.com/profile.php?...=1443097048202
Old    JDUB (jward10)      Join Date: Mar 2007       05-17-2010, 10:14 PM Reply
looks good, just edge harder
Old    Gene Williams (gene3x)      Join Date: Apr 2005       05-18-2010, 3:41 AM Reply
Load the line a little more, meaning have as much line tension as possible when you hit the top of the wake. Maybe carry a little more speed but as that line tension is released at the top push off hard with your legs by standing tall.
Old    Josh (hyperlite)      Join Date: May 2009       05-18-2010, 5:32 AM Reply
LOL....the phrase that pays "Just edge harder!"
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       05-18-2010, 7:40 AM Reply
I agree with everything everybody above has said. Just need a bit more gusto coming into the wake. You're standing up at the wake and keeping the rope in well, just need some more speed. Maybe try upping speed on the boat to 22 or 22.5 if your comfortable with it. That'll make the wake a bit more firm, narrow it out a foot or two potentially, and allow you to get more speed when you cut in.
-Good luck!
Old    Daniel Lorenze (dan_lorenze)      Join Date: Mar 2009       05-18-2010, 8:21 AM Reply
I've been having the same issue here.. A friend of mine who rips told me to take the line down to 60' and don't look down, look at the horizon otherwise you look down and thats where you're headed...
Old    Ty (wakeandsnow27)      Join Date: Jun 2004       05-18-2010, 9:16 AM Reply
I agree with the masses here.... One little trick I've found works great when people need to clear the wake/go bigger is to try and get your butt closer to the water when you edge in. Sit back on the rope, edge hard...and just think of your butt touching the water...you'll gain a ton of speed, which imo is all you need. The pop is there, your just not traveling across the wake once you get up.
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       05-18-2010, 10:06 AM Reply
I watched the video. In my opinion, your speed/line length formula is off. Yeah you could have edged harder to make it happen, but the wake looked pretty wide to me. I'd bump up the speed a little, or shorten the line if the faster speed is not comfortbable for you.
Old    Tampa Wake (tampawake)      Join Date: Mar 2008       05-18-2010, 10:59 AM Reply
Yep 70 ft looks like your wake is better there edge harder. Look where your going not down which is hard to do.
