Old     (corbin)      Join Date: Jul 2009       03-23-2010, 5:00 PM Reply
I've got a Mercruiser 350 MAG MPI but I don't have any marine stores in the area so I have to order online. Can anyone tell me what impeller I need?
Old     (yubasanger)      Join Date: Jul 2007       03-24-2010, 12:05 AM Reply
Year and serial # of motor?
Old     (ottog1979)      Join Date: Apr 2007       03-24-2010, 9:06 AM Reply
Year?
Old     (justintime)      Join Date: Mar 2009       03-24-2010, 12:30 PM Reply
we need serial number
Old     (corbin)      Join Date: Jul 2009       03-24-2010, 7:50 PM Reply
Sorry... I knew I needed that info but forgot completely to add it in.
The boat is a 2001 Sanger and I'm pretty sure it's the original engine The serial number is 0(zero)L676198
Old     (justintime)      Join Date: Mar 2009       03-24-2010, 9:18 PM Reply
47- 593621 is mercury part number
boats.net is the cheapest back east
Old     (yubasanger)      Join Date: Jul 2007       03-24-2010, 10:19 PM Reply
The 47-593621 was superseded by the 4759362T1 you have the one piece plastic housing look closely for signs of wear in the back of the housing and on the metal wear plate replace if necessary. If you need to replace the plastic housing you can purchase a kit that includes part #'s 2,3,4,5,6,7&8 part # for the kit is 46-807151A14 and costs around $80. I always recommend that people replace the entire housing as I said before these are prone to wear, some people chose to swap the entire pump for a brass Jabsco, but that will set you back $350-400. Impeller should cost around $20. by itself.
Old     (corbin)      Join Date: Jul 2009       03-26-2010, 8:51 PM Reply
What parts are replaced for just general maintenance? My guess would be the impeller, the wear plate, and what looks like the two o-rings (3 &7)
Old     (BoatFreak)      Join Date: Mar 2010       03-29-2010, 7:27 PM Reply
Check out www.inboardonline.com. We are offering a 10% discount if you use the promo code IOLROCKS.
Just give them a call, they can tell you which part you need if still unsure. 877-327-7175
Good Luck!
Old     (mendo247)      Join Date: Mar 2005       03-29-2010, 8:19 PM Reply
Just go to the Mercruiser Website. I just registered my motor and ordered all my parts through them. Worked out great.
