Old    Brett (bmcgee)      Join Date: Nov 2007       03-22-2010, 7:29 PM Reply
The cruise control in my 99 Chevy silverado 1500 recently went out. When I push the button to set it, nothing happens. Usually a light will pop up on the dash that says "cruise". But now, absolutely nothing happens. Does anyone have any ideas as to what it could be? I've checked the fuses/relay and everything checked out just fine.
Thanks
Old    Rob Bennett (Robatl)      Join Date: Mar 2010       03-22-2010, 8:09 PM Reply
first off which you probably already done turn the switch for cruise off then back on while its running. if thats not the problem the switch is probably gone bad. mine did a while back on my car and it was around 300 bucks to replace.
Old    Brett (bmcgee)      Join Date: Nov 2007       03-22-2010, 8:51 PM Reply
Yeah, i've tried that a few times. By switch, do you mean the part on the steering column/blinker handle? I'm not sure if I want it bad enough to throw down 300 bones towards a new switch. Is replacing the switch pretty straight forward?
Old    Shaun Brinkle (highrock)      Join Date: Apr 2008       03-23-2010, 6:37 AM Reply
Check your fuses too before going to buy anything.
Old    Brett (bmcgee)      Join Date: Nov 2007       03-23-2010, 10:49 AM Reply
^^ That was the first thing i checked and I didnt find any blown fuses
