Old     (fill_er_up)      Join Date: May 2006       03-09-2010, 6:18 PM Reply
2000 Tige w 350 Mercruiser and ready to change fuel-water separator. Do I just bear down and spin it off or do I need to relieve pressure or anything first? Input appreciated
Old     (rio_sanger)      Join Date: Apr 2007       03-09-2010, 6:36 PM Reply
Been changing mine annually on my '99 Merc since new.
Never "relieved" any pressure, just uscrew and replaced. No problems here so far, don't know if there is another method, but would be curious to hear if so.
Old     (wake_upppp)      Join Date: Nov 2003       03-09-2010, 6:37 PM Reply
Fuel injected? If so as long as it's been a few hours since it's been ran, the pressure should of bled off. If you just ran it then it will have pressure. Either way some fuel will spill. Put a towel/rag under the filter and crack it open slowly.
Old     (fill_er_up)      Join Date: May 2006       03-09-2010, 7:22 PM Reply
Engine is the 350 MAG MPI Ski. I saw something when random searching online about turning off fuel supply or relieving pressure to stop fuel spray, but did not know of any fuel cutoff and did not know if pressure would be maintained even when engine had been off for awhile. Tks for the feedback
Old     (Bakes)      Join Date: Mar 2010       03-09-2010, 7:30 PM Reply
Just unscrew it. Did mine on my 98 tige last week. I needed to use one of those strap wrenches to get it off though. Don't forget to fill it up with gas before you screw the new one back on. While you are at it you should swap out your cap and rotor. My engine was running a little rough and swapping out the rotor made her super smooth again.
Old     (wake_upppp)      Join Date: Nov 2003       03-09-2010, 8:05 PM Reply
Filling the new filter is optional. Not filling it wont hurt anything but the engine may start a few seconds earlier if you put some in there.
