Old    Baitkiller (baitkiller)      Join Date: Jan 2010       03-07-2010, 2:09 PM Reply
Is this pre or post wood stringer era?
Also can I stash enough weight out of view for a family wake? I don't need a surf wake and my crew is very young and just learning so W2W stuff will be about it.
You experienced opinion is appreciated.
John
Old    BELEZA (beleza)      Join Date: Mar 2010       03-07-2010, 10:09 PM Reply
I'm pretty sure the sport nautique went away from wood stringers in 93. 89-92 had wood.
The Sport will throw a good beginner wake with no weight. Throw a single fat sac in the back behind the engine compartment and it will beef it up a bit. Once your crew outgrows the wake, just add acouple more sacs and you will be golden. It will be a bit crammed if you have more than a couple sacs, but the wake will be good.
I had a Sport for many years and it was a great boat.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       03-08-2010, 4:27 AM Reply
Thank you. The issue is that the boat is 4.5 hours away. When I go I want to take my truck and a check. Not my percussion hammer and moisture meter.
If it looks like it looks and actually starts on a hose. Fine. The last three boats I looked at all had rotten grids.
I guess Ill get the HIN from the seller and call CC.
Again thank you for your response.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       03-08-2010, 7:18 AM Reply
OK CC says no wood in the stringers but she has a plywood deck. Does anybody know if the seat backs are all plywood too? Sorry for all the ???. It's a long drive to see the boat and the seller is less informed than I am.
