Old     (breazy)      Join Date: Jun 2009       03-03-2010, 11:33 AM Reply
Found this article from the Nissan Forum I frequent. Seems like its mostly a minor issue and should be easily remedied by dealers, but if your vehicle is one of those affected please get it checked. I don't want to hear of any failures while towing these heavy arse boats. Note this recall isn't because of accidents or anything like that, Nissan is just taking a proactive approach to ensuring the quality and safety of their vehicles.
full article here; http://business.timesonline.co.uk/to...cle7047601.ece
Originally Posted by Times UK
The brake-related recalls affect the Titan pickup truck and the Armada and Infiniti OX sports utility vehicles. The same models are being recalled for fuel gauge problems, as well as certain Frontier, Pathfinder and Terri models. The affected cars were sold between 2006 and last year. Nissan said today that versions of those cars currently in showrooms have already received the necessary fixes.
Old     (wakereviews)      Join Date: Sep 2006       03-03-2010, 1:52 PM Reply
Thanks for the heads up, my car is going in Tuesday and I called to remind them to check the recalls!
Old     (gregtay)      Join Date: Aug 2008       03-03-2010, 2:16 PM Reply
I highly recommend everyone had the gas gauge issue fixed... last summer i ran out of gas in my 08 Armada while towing my Malibu to the lake... gauge showed over a 1/4 tanks. Luckly my friend was just down the road filling gas cans for his boat and we trough some gas in the Armada just to see if maybe somehow i ran out of gas... sure enough.
Old     (jaybee)      Join Date: Aug 2007       03-03-2010, 5:10 PM Reply
Thank you for the heads up. I will be calling nissan tomorrow.
Old     (witness140)      Join Date: Dec 2008       03-04-2010, 7:53 AM Reply
For those with 05-07 Pathfinders, if you haven't changed your transmission lines to run through an after-market external transmission cooler yet - might want to do it quick.
Do a search on the net and you will see how many folks are having issues with the factory lines deteriorating within the radiator core. This leads to antifreeze heading into the tranny, and tranny fluid into the cooling system.
One early symptom isn't actually the transmission having issues - it is an apparent lack of cabin heat with the engine up to operating temp. Then some transmission 'shudders' then complete failure.
$4000+ to have fixed at Nissan, and they won't typically want to help anyone out. Known issue, tons of stuff on the net about it, but no factory action yet.
Friend of mine is going through this now. Same tranny is in the Frontier, Xterra, Pathfinder, and even some of the cars in the Nissan/Infiniti line. The Pathfinder is the only one with this cooling loop issue AFAIK.
Usually fails around 70-80K.
Old     (captain_542)      Join Date: Oct 2006       03-05-2010, 11:03 AM Reply
Thanks for all the info. Im driving to FL from Wisco in a few weeks. Will definitely be checking everything out before I leave. Thanks again
