Old    Big Stick Rick (rickykamberra)      Join Date: Dec 2006       02-17-2010, 5:34 PM Reply
I own a 2000 Moomba Kamberra. I took it out a couple of weeks ago and the boat struggled to start. Once I got it going it wouldn't idle, so I kept it in neutral and the throttle down a bit. It was really smokey and ran rough. Could this be the carb? We had it out a couple of weeks before that and it ran great.
Old    Peter_C (peter_c)      Join Date: Sep 2001       02-17-2010, 5:41 PM Reply
Holley carb? Check the power valve! By smokey do you mean kinda a black smoke?
Edit: Did it back fire through the carb when this issue started?
(Message edited by peter_c on February 17, 2010)
Old    TigeMike (chpthril)      Join Date: Oct 2007       02-17-2010, 5:44 PM Reply
Sounds like a stuck choke. I'm guessing is has an electric fuel pump, so that leaves out a ruptured diaphragm.
Old    Big Stick Rick (rickykamberra)      Join Date: Dec 2006       02-17-2010, 5:52 PM Reply
Yes, Holley carb - 4 barrel.
it was black smoke.
put in a new electric fuel pump last year.
My buddy said it might be the stuck choke too?
Any suggestions? he said that I might tap it with something???
Old    Big Stick Rick (rickykamberra)      Join Date: Dec 2006       02-17-2010, 5:53 PM Reply
oh, also, not back firing through carb that was noticed. it just seemed like it would run if I kept the rpms high, but it was rough and smokey. If i pulled it back down it would die.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       02-17-2010, 6:01 PM Reply
Its loading up for some reason. Stuck choke like earlier mentioned is probably the cause. Next time out check that the choke plate is open after it warms up.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       02-17-2010, 6:06 PM Reply
Check float level,possible trash in the needle and seat,power valve. I would turn the key on so the fuel pump will run not the engine. Look in side the front two barrels and see if fuel is dripping.
Old    Peter_C (peter_c)      Join Date: Sep 2001       02-17-2010, 6:16 PM Reply
Power valves are the single most common reason for that. Check the choke it is easy to look down the carb with it running and see if the choke is open. You can pull the plug out from the side an check the fuel level for a stuck float or damaged needle/seat.
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       02-17-2010, 6:50 PM Reply
Next time you run it. Put the throttle at about 3000 -3500 and see if it smooths out. If it does then you are just dumping to much fuel. peter is correct Holley's are known for blowing power valves.
Old    Steve Oh (olskooltige)      Join Date: Mar 2007       02-18-2010, 8:54 AM Reply
Peter, no sight plugs on every 4160 I've seen.
Old    Harold Hemming (h20king)      Join Date: Dec 2009       02-18-2010, 9:07 AM Reply
power valve is not the problem the newer carbs come anti backfire devices to protect the power valve.It does sound like carb problems though.most common is a condition called VD venchuri discharge.with engine running at idle look in to the carb if you see fuel dripping down the barrel it's VD and time for a rebuild
Old    C.I.E..... Evan (guido)      Join Date: Jul 2002       02-18-2010, 11:12 AM Reply
I like a stuck float, especially if it was fine when you put it away. Be careful looking down the carb on a engine that isn't running right. Taking a backfire in the face is a bad deal. Preferably wear some eye protection, if not a face shield when working on a running carb'd engine.
Any way you look at it, it sounds like the carb is coming apart.
Old    Sam (wake1823)      Join Date: Dec 2005       02-18-2010, 1:02 PM Reply
High Jack.
I've got 2 stroke jetskis ( carbed) that run fine at idle and high speed, but in order to get them to run at high speed you have to pull the choke which kills the motor, then restart, and it will run like a scalded ape. I have to do this almost every time coming off plane. one is worse thatn the other. Almsot liekt he bowls are not filling with fuel???
Old    Peter_C (peter_c)      Join Date: Sep 2001       02-18-2010, 1:37 PM Reply
The carb still has a power valve and they can fail without having ever seen a backfire. I did some research on the model that Steve says it is. Seems like they made some improvements to it. The two bent tubes at the top of the float bowls going into the carb should be the overflow for the float bowls. So if the problem is the float level or a leaking seat it should easily be seen coming out these tubes.
Thanks Evan for reminding everyone to keep stupid at bay.
Old    Jonathan Bay (john211)      Join Date: Aug 2008       02-18-2010, 2:17 PM Reply
" ... stupid at bay." ?!?!?
Old    Peter_C (peter_c)      Join Date: Sep 2001       02-18-2010, 2:30 PM Reply
Mr. Bay is stupid there now?
I sure hope you don't take offense to a commonly used saying.
Old    Jonathan Bay (john211)      Join Date: Aug 2008       02-18-2010, 4:00 PM Reply
I take offense to it like some to the r-word.
It's use is only morally defensible if limited to 'able-minded people' and within the 'satire' exception.
http://www.thedailyshow.com/watch/mon-february-8-2010/back-in-black---the-r-word
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-18-2010, 7:35 PM Reply
Sam (wake1823)
what ski's? your pop off pressure sounds wrong on the carb
is is called venturi
take the flame arrestor off and look for dripping fuel
always when you rebuild the carb, never soak them in carb cleaner, marine carbs have a special sealer on them to keep moisture out of them. Also replace the fuel filters and clean the spark plugs and look at the cap and rotor
Holleys are also know to air leak around the throttle shafts
to test, spray carb cleaner around the shaft when motor running at idle
if it picks up RPM, you have a leak!!!
Old    Dave Gonyea (gonyeasmarinecom)      Join Date: Feb 2010       02-19-2010, 12:14 PM Reply
Just from the tech corner, if you have a 4160 holley carb and have not used the vessel in some time, most likely the needle is not sealing at the seat (even a piece of corrosion) will do it.
not to mention the E10 problems that are starting to plaque our industry. to diognose the problem, apply water to feed under boat set choke
by pushing accelorator down once return to idle position push or pull out button, set to desired fast idle and start remove spark arrestor let engine warm up put helm control to idle, look down airhorn at venturi's if you see fuel coming from these at idle your float level has become to high a rebiuld is the remedy. have a qualified
technician rebuild it. holley carbs are the most
advanced american carbs as with amarica there are
t.s.b. technical service bullitens "be aware"
as for some coating to prohibit moisture on the carbs that bull. and worn throttle shafts yah if was a 1984. you must use a genuine holley marine kit and power valve check kit installed if it does not have one. ta ta
Old    Dave Gonyea (gonyeasmarinecom)      Join Date: Feb 2010       02-19-2010, 12:33 PM Reply
The two vent tubes are bent down for a reason
"marine only" application so if the floats stick open the overflow of fuel will food out the engine,& not run everywhere and ignite by a spark
thus having an explosion and the picnic is over.
cold tanks are fine for carb cleaning, also a fuel water separator system is a must, E10 E10 ta ta
Old    Jonathan Bay (john211)      Join Date: Aug 2008       02-19-2010, 1:01 PM Reply
i visit this thread out of curiosity because, long time ago, i tried to re-build a carb on my own. fail.
mine was on an 8 cyl '73 chevy. it had a spaghetti-work of all these oddly bent linkage rods. (along all sides ??? iirc.) the goal was to re-bend those rods to adjust the output travel of the output ends to be at certain points for certain points of the input ends. could not do.
it looked nothing like that Holley. that Holley is clean looking, seemingly free of all the linkages
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-20-2010, 12:36 AM Reply
holleys are e-z to rebuild, you can get to everything, cept power valves, without removing the carb from motor
yes there is a coating on the carbs
call mallory marine and ask
so why was the HOLLEY carbs recalled in 2002-2006???
Old    Dave Gonyea (gonyeasmarinecom)      Join Date: Feb 2010       02-22-2010, 2:36 PM Reply
hey stay in your books but stay out of the garage. guys like you make me a lot of money. ta ta
Old    Sam (wake1823)      Join Date: Dec 2005       02-22-2010, 3:08 PM Reply
just-in-time...they are 97 yamaha waveraiders...one is the triple carb 1200 the other is dual carb 760 I think?
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-22-2010, 6:26 PM Reply
SAM
yes rebuild the carbs
if you want the service manuals, email me
Yamaha manuals are not the greatest, because they were translated from Japaneese
DAVE
if your quoting me, not very cool as an owner of a marine dealer
Old    Dave Gonyea (gonyeasmarinecom)      Join Date: Feb 2010       02-22-2010, 7:19 PM Reply
Justin I am not quoting you, its just the 4160 has been in marine use since the v8, I myself have o/h over 100 since it is such a popular carb
everyone seems to know a little something about them some more than others, manuals tsb's recalls
just look at these blogs it's a famous carb
but in my 20 years there have been numerous times
the diy says hay I just went through that carb or
just had it done by a mechanic ya there is one on every corner, ya see my point, even manuals are wrong sometimes. no hard feelings. Dave
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-22-2010, 7:26 PM Reply
Yes same carb on my 351 Bronco, better then the 4 barrel quad jet
The best book on that carb is the PCM manual or the holley carb itself
no hard feelings, i though you were referring to me, LOL
these newer holley's were recalled because they are made in china now, and they used tin inside the carb vs zinc!, LOL
Old    frank davis (ftd)      Join Date: Apr 2004       02-23-2010, 9:12 AM Reply
Spray/clean well with carb cleaner. Run a can of Sea Foam through. S/b good to go. I just went through this with my 1998 Moomba.
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-23-2010, 11:51 AM Reply
spraying carb cleaner in a carb does absolutely nothing except maybe clean the piston tops of carbon
the seafoam might help out
Old    frank davis (ftd)      Join Date: Apr 2004       02-23-2010, 6:24 PM Reply
"spraying carb cleaner in a carb does absolutely nothing"
I beg to differ. It will clean spooge off choke shaft and associated linkages and thus help if the problem is in fact a poorly operating choke mechanism.
A can of carb cleaner and a can of Sea Foam before any carb rebuilding is definitely the route to take.
Ockham's Razor!
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-23-2010, 8:28 PM Reply
still that does nothing
when you rebuild the carb, you take car of it
it is the internals that you want to clean
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       02-23-2010, 8:43 PM Reply
"even manuals are wrong sometimes" Man aint that the truth. Dont tell that to someone who believes everything has to be done "by the book". Spraying carb cleaner does plenty. It works great for free-ing up sticky and dirty linkage, which sometimes is the problem.
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-23-2010, 9:50 PM Reply
Sparkels
right out of the HOLLEY book
they make the carb, no way they are wrong, that is why they do service bulletins
if they were they would be sued!
Old    Aaron Ware (99_slaunch)      Join Date: Oct 2005       02-24-2010, 5:53 AM Reply
"Experienced technicians develop their own order or method of disassembly" With that statement they are even saying you don't have to do it by the book. By the book is a suggested method NOT the only method.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       02-24-2010, 12:22 PM Reply
Justin: and your point is what? That carb and choke cleaner still does "nothing". Thats it I'm going to sue the liars that sell it! LOL
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-24-2010, 12:44 PM Reply
what im saying about carb cleaner is
spraying down throat does nothing internally to the carb, that is where the varnish resides
