Old     (joesell)      Join Date: Apr 2001       03-26-2010, 3:54 AM Reply
I honestly don't know about the red line beep. We only had it out 4 times at the end of last year, but I never heard any beeping.
Nic, I didn't get a chance to go over by my boat. My little guy chipped a tooth, so we had to take care of that. Tonight for sure though.
Old     (_vitty_)      Join Date: Jul 2009       03-26-2010, 9:08 AM Reply
Oh no good Joe!! Sorry to hear that. Whenever you get a chance is all good
Twitch, you don't want to remove that beeping noise. It is there for a reason. If you continue to run it at 5000rpm(causing the beeping) it will limit fuel, then after a bit it will put the boat into limp mode at which point it would really take you a long time to get across the lake. If you never heard the beeping and continued running it you would never know the boat was about to make you limp to your dock.
For surely do not override the limiter. Above 5000rpm these engines will fall apart quickly. Merc won't cover you if you over-rev it, at which point you better hope you have $21,000 laying around to replace it
If you want more top end speed you are going to need replace the prop with one that has a longer pitch. Right now it's set up to yank trees out of the ground from a standstill, which is what you want in a wakeboard boat. If you are willing to sacrifice some get up for more go, then a longer pitch prop is what you need.
Old     (themxercr85)      Join Date: Jul 2007       03-26-2010, 6:23 PM Reply
haha well put Nic. Im not necessarily looking to gain top speed I just hate the noise. I dont like to red-line it either but when I accidentally do the beeping pushed my buttons haha. I watch rpm anyways so there isnt much need for it. Theres no way I would sacrifice the hole-shot that thing has for top speed. Thats why we have two donzis =D
Old     (joesell)      Join Date: Apr 2001       03-26-2010, 6:39 PM Reply
Here are some pic's of the batteries. The one closest to the rear is the stereo batt. This is the one with a bunch of connections for all kinds of stuff like the amps, and the distribution blocks. The one in the front is the starting batt. They both use ring terminals for everything.
Old     (joesell)      Join Date: Apr 2001       03-26-2010, 6:40 PM Reply
I forgot to mention that I have an on board batt charger hooked up. So disregard the orange, and yellow wires.
Old     (_vitty_)      Join Date: Jul 2009       03-26-2010, 8:44 PM Reply
Thanks for the pics Joe! This helps me figure out what type of connectors I need.
I am going to try to stuff 3 of these guys into that compartment to power just the accessories/stereo. Going to be a very tight fit. Hopefully I can get them all crammed in there.
The two original batteries that came with the boat are being relocated to the boot luber compartment and will be used as the crank batteries. Wish me luck!
Old     (_vitty_)      Join Date: Jul 2009       03-26-2010, 8:45 PM Reply
Also, do you know off the top of your head if the amplifiers are grounded all the way back to the battery negative?
Old     (_vitty_)      Join Date: Jul 2009       03-27-2010, 7:32 AM Reply
One more quick thing....could you by chance tell me how wide and tall the area is under the driver's feet? Also how deep is from where the walkthrough panel starts to the inside of the driver's feet area?
What I am trying to do is plan out a subwoofer box that will fit under there and not hang past that walkthrough panel. Here are my proposed dimensions:
16"H x 25"W x 8.5"D
Maybe it would be easier to just tell me if that would fit under there and not hang out
I should owe you a case of beer or something haha
Old     (joesell)      Join Date: Apr 2001       03-27-2010, 4:37 PM Reply
Nic, I believe they are grounded back. It would be stupid to run 2 - 4 ga wires for the power, and not ground it properly. I'll double check it though.
I really don't think your going to get 3 of those in that hole. Your also going to have a hard time fitting the 2 stock batteries on the other side. I think you might be forgetting about the steering cable that runs through the middle of it.
I'll measure for you tomorrow.
Check your messages
Old     (_vitty_)      Join Date: Jul 2009       03-27-2010, 9:16 PM Reply
Thanks Joe!
My final box dimensions are 16"H x 25"W x 10"D for when you measure.
I had some rough dimensions of the battery compartment on an old note from last fall. I had 17" wide, 18" long, and a battery less than 10" tall would work. Based on those dimensions I believe I can squeeze 3 of the d2700's in, but we shall see when the time comes. The batteries will be here this coming week, but I think its going to be another week or two before the boat comes out of storage.
As far as moving the two batteries to the other compartment, I am just going off of Greg at Epic saying that the compartment on that side is the same size as the battery compartment. I think I only briefly looked in there once. Worse comes to worse, 1 battery should fit over there and that should suffice for a starting batt.
Old     (_vitty_)      Join Date: Jul 2009       03-28-2010, 12:35 PM Reply
Joe,
Check out the Hellroaring products for battery isolator/combiners http://www.hellroaring.com/marine.php
I have been reading that they do not cause the voltage drop that is inherent with diode style isolators(surepower 1314). The more I read up on isolating the two banks of batteries I have the more I become confused.
Old     (joesell)      Join Date: Apr 2001       03-28-2010, 7:40 PM Reply
I don't think the 1314 is a diode style isolator. I think it's a relay style. I'm pretty sure the stock isolator on our boats is the diode style. I could be wrong though, it happened 1 other time.
Old     (_vitty_)      Join Date: Jul 2009       03-28-2010, 8:12 PM Reply
I think you are correct on it being a relay style versus a diode style. Good call. I'm so f'ing confused with all this.....
Latest thought is to get a 1314-200(in case I upgrade the alternator) and hook my battery banks up the same as you. I would also then see if I can rig up a solar power option for an onboard charger.
Old     (joesell)      Join Date: Apr 2001       03-29-2010, 5:59 AM Reply
Nic, I think you'll be happy with the Pro Sport 20. I got one last fall, and installed it on that shelf below the subs in the rear. The grey tubing is just some wire wrap I put on the thru-hull for the boot lubber. That way if water ever gets in there, it won't splash right on the charger.
I cleaned up the wires since the pic also. That was mid install.
Old     (_vitty_)      Join Date: Jul 2009       03-29-2010, 9:27 AM Reply
After all is said and done I think I have finally settled on a Hellroaring BIC-95150B. They are more expensive, but after talking with Mike Hines at Hellroaring he has given me the most confidence that this will do the job for me and do it well. He knows his stuff, answers my questions clearly and concisely, and most of all he layed out a system configuration for me that is both easy to understand and won't run into ANY hiccups unlike some that I might have ran into with the SurePower 1314.
Joe, if you want me to send you the email conversation I had with him shoot me your email addy. These really sound like the no hassles, install once and forget about it solution we are looking for.
Old     (_vitty_)      Join Date: Jul 2009       03-29-2010, 4:08 PM Reply
Batteries came today. Here is how they will be arranged in the battery compartment.
They measure 13 1/4" wide, 18 3/4" long, and about 9" tall with battery posts on them.
Hope they fit in the compartment
Old     (_vitty_)      Join Date: Jul 2009       04-01-2010, 5:47 PM Reply
Got the custom piece for the transom made. Here it is in raw material form, no holes or paint yet.
Old     (joesell)      Join Date: Apr 2001       04-02-2010, 8:41 PM Reply
I've been pretty busy the last few days working on the boat. I made a lot of progress though. I gat the second heater installed and all the wiring, hoses, and vents installed. I also moved the rear right vent to the walk-thru area. In the walk-thru pick, you can see the channel that we made to hold the wind dam. The wind dam itself isn't done yet, but the channels that it'll slide into are done, and installed.
Old     (joesell)      Join Date: Apr 2001       04-02-2010, 8:45 PM Reply
The dash vents were pretty hard. I used a 1/4" air ratchet to drill the pilot holes, but I had to hand drill the 3" holes. It took a while, but it turned out perfect.
Old     (_vitty_)      Join Date: Jul 2009       04-07-2010, 10:37 AM Reply
Getting my boat out of storage today!! Then the fun begins
Old     (tuneman)      Join Date: Mar 2002       04-08-2010, 9:15 AM Reply
Nice work, Joe! Looks great.
Old     (usostyle)      Join Date: Apr 2006       04-10-2010, 10:10 PM Reply
Guys- Does your sea temp (aka- water temp) guage work? It's listed on the same screen as the air temp which works just fine, but my 'sea temp' always says 'off' and I cannot seem to figure out how to turn in 'on'?
Old     (joesell)      Join Date: Apr 2001       04-11-2010, 7:18 AM Reply
Mine works, but I'm not really up to speed on the gauge functions yet. I haven't gotten out enough yet.
Old     (DMA)      Join Date: Mar 2010       04-12-2010, 10:19 PM Reply
Nic-
Talked with Colin aka/Twitch today and he said you wanted the paint code for your Epic. You will have to take a piece that you cut out to your boat. The take it to your local body shop and have them match the paint for you. If you want to spray it yourself then find the location of the company that supply’s the body shop with paint and have them mix you up some.
Shane
Old     (_vitty_)      Join Date: Jul 2009       04-13-2010, 6:24 AM Reply
Thanks Shane! My budget didn't allow me to use you guys unfortunately or I would have in a heartbeat. You do excellent work!
Old     (_vitty_)      Join Date: Jul 2009       04-13-2010, 6:27 AM Reply
What do you all use to clean the foam flooring on our boats? Mine is getting absolutely filthy during my install. It is just the standard grey so I'm sure it shows dirt a lot more than the camo print.
Old     (joesell)      Join Date: Apr 2001       04-13-2010, 7:29 PM Reply
I got the 3rd batt installed. I ended up using some 3M 5200, and glued down a piece of aluminum to mount the batt tray to. It went well, but I realized that there isn't nearly as much room in the drivers side rear hole as I thought. There's 3 big ballast hose's, the pump and contoller for the trim tab, and the biggest space hog of all, the steering cable. The problem, that I didn't realize at first, is that the cable has to swing a little when you steer. So it ends up taking up a lot of room. You can see it in the pic's.
I'm not quite done yet. I had to order 1 more fuse holder like the one in the pic.
Old     (joesell)      Join Date: Apr 2001       04-13-2010, 7:36 PM Reply
I installed the surepower 1314, and I got a manual disconnect switch so I could manually separate the start, and stereo banks during shore charging. I also got a thru-hull connector for the 3 bank Promariner battery charger. Everything went really well. I'm happy with the install.
Old     (joesell)      Join Date: Apr 2001       04-13-2010, 7:38 PM Reply
The pic's didn't work on that one.
Old     (joesell)      Join Date: Apr 2001       04-13-2010, 7:44 PM Reply
I started installing the caps yesterday. I got as far as figuring out how I wanted to run the wires, and where to mount them and the distribution blocks. It's pretty hard for me to get inside the cubby hole under the radio. so I had to make a template out of cardboard that I could drill through. I'm hoping to get them done tomorrow.
Old     (samhanna)      Join Date: Sep 2009       04-15-2010, 8:46 AM Reply
Does the epic have a battery disconnect anywhere. My Malibu had a perko switch to turn the batteries off when it was stored. My Epic sat all winter and now the brand new batteries dont seem to be holding a charge. Am I missing it somewhere?
Old     (joesell)      Join Date: Apr 2001       04-16-2010, 3:49 AM Reply
No stock disconnect. Did you have a float charger on them over the winter? If not, they might have froze. No big deal, they have a warranty.
Old     (samhanna)      Join Date: Sep 2009       04-16-2010, 7:09 AM Reply
No I did not charge them. Where do I take them for warranty replacement?
Old     (joesell)      Join Date: Apr 2001       04-16-2010, 8:02 PM Reply
You have to find a local dealer. I forgot what brand they are. Take your boat paperwork with you so you can prove how old they are.
Old     (joesell)      Join Date: Apr 2001       04-18-2010, 7:56 PM Reply
I got a lot done this weekend. I finished installing the caps. Finished the wind dam. Finished installing the panel with HSE, and the WS420. Vacuumed the boat. Cleaned and sprayed the seats down with Babe's.
Old     (joesell)      Join Date: Apr 2001       04-18-2010, 8:08 PM Reply
My original list grew along the way, but I got it all done except for the garbage hole. I'm still looking for a way to make it look right. I'm really happy with the way everything turned out.
Old    ScottRobinson            04-19-2010, 7:03 PM Reply
Hey Joe, your wind dam is SICK!! I may call you and have you build and ship one to me.!! I will find out if EPIC did anything about this and let you know. If not I will either ask how you made it or ask you TO make it. =)
Old     (usostyle)      Join Date: Apr 2006       04-20-2010, 7:00 AM Reply
Joe- nicely done, on all of it!
Sounds like our weekends were a bit similar, we got our wind dam done as well and gave the Epic our thorough 'pre-season' cleaning. This is the first time we have ever used Exquisite upholstry cleaner...WOW! Followed that up with some babe's and it was all good.
I also used the Exquisite to clean the rubber flooring and it worked great too. It didn't seem like it would hurt the rubber flooring, but please correct me if you guys think otherwise.
Scott-
Here's what I did for our wind dam and what I would suggest. Call Scott @ Samson Sports (same company that manufactures our Razor towers on the Epics). Let him know that you are doing with I did for a wind dam. The channeling is the same channeling that is on our towers that the bimini tops slide up and down along in.
Let Scott know you want the following-
(2) 24" channeling with 4 counter-sunk holes drilled in them and have him round off and router both the top and bottom edges to ensure people don't scratch or cut themselves when walk by the rails from the bow to the back of the boat.
(8) 3/4 stainless screws.
If he asks about the rubber stoppers that he sent me, advise him they are not needed
I installed them straight down from the windsheild. Pre-drill your mounting holes and obviously make sure thing are straight and the two rails are in line with each other. You will notice that from the floor to the bottom of the windshield is more like 28" or so, stick with the 24" rails to compensate for the curve at the bottom where the sidewalls meet the floor.
Once the rails were installed, I took my boat to a plexiglass shop and had him cut & fab me a 3/4 peice of plexi to fit exactly. Make sure that he makes it as snug as possible up top to seal using the rubber seal that is on the bottom of the windshield. I got my Epic emblem that Joe and I have on ours from my Epic dealer.
Total cost of wind dam-
$25 for channeling fab, screws, holes drilled including shipping (samson sports)
$45 for Plexiglass
$45 for custom fab and fit of plexiglass
Total= $115
Attached are some pics, some of the pics were taken 'before' we gave it it's pre-season cleaning so you will see some dirt and grime in the backround :-)
Did I mention...Exquisite...HIGHLY RECOMMENDED, when I was done cleaning the boat I walked around my garage looking for vinyls, plastic, rubbers that I could shoot and clean, (kids bikes, seats, chairs, my rubber boots, etc) this stuff is amazing...
Old    ScottRobinson            04-20-2010, 7:15 AM Reply
Very cool!...thanks for all the info! Haven't talk to Gary yet to see if Epic has done anything about this on the 2011 yet. Love the fact that you guys can do all this. AMAZING! You guys are KICK ASS !
Old     (joesell)      Join Date: Apr 2001       04-20-2010, 2:35 PM Reply
Ice, very, very nice!
They definitely cut yours a lot cleaner then mine. I had to use a jig saw, and some sand paper.
How much did you dealer charge you for that sticker? I need one for the front of mine. The one I have, I got in a care package.
Just to give you guys a little sneak preview, w/o pic's of course. I got some 1/4" aluminum, about a month ago, that I gave to my machinist buddy.
He hasn't had time between jobs yet, but he's going to cut and polish two big "Epic" decals out of it for me. They'll be 4 1/2" x 36". That's the exact scale of the smaller 1 1/2 x 12 sticker on the tower. I'm going to mount them on the gunnel between the tower and the rear hatches. They're going to be a "fancy" place to step. I'm really excited about them. The wait is killing me.
Old     (usostyle)      Join Date: Apr 2006       04-20-2010, 2:52 PM Reply
Joe-
Thanks, we are happy with the way it turned out. I got the sticker emblem from my dealer, he just gave me a couple. email me your address and I'll send you the other one that I have.
Regarding the 'fancy' step plates, stealing a line from Gatorade....
"That's G"...that's all I can say. Are you going to put some grip tape on the top of them? Can't wait to see them...
Old     (joesell)      Join Date: Apr 2001       04-20-2010, 3:51 PM Reply
No grip tape. Don't want to mess up the clean look. Besides, I have to balance and agility of a jungle cat.
Really though, they're going to be 1/4" thick, and cut out like the sticker. Should be plenty of toe grip there.
Old     (_vitty_)      Join Date: Jul 2009       04-21-2010, 5:21 PM Reply
Finally finished my filler panel for the transom speakers. Here it is from start to finish.
Raw board
Raw board cut for 4 wet sounds xs-650's
Raw board with speakers placed in
Final product painted panel, with notches for the speaker connections
Final product other view
Old     (joesell)      Join Date: Apr 2001       04-21-2010, 5:49 PM Reply
Nice dude!
I don't know if you noticed, but there's a big rat in some of your pic's
Old     (_vitty_)      Join Date: Jul 2009       04-21-2010, 7:10 PM Reply
Thanks man! Going to install it tomorrow. Will snap some pics once its on tomorrow night.
Where did you get those heater vent flange assemblies that match the oem ones?
Old     (usostyle)      Join Date: Apr 2006       04-22-2010, 8:48 AM Reply
Joe- Emblem is in the mail, should be there on Monday. I also sent you a few Orange Epic stickers you may like. Let me know once you get them to make sure they made it to you.
Old     (_vitty_)      Join Date: Jul 2009       04-22-2010, 1:18 PM Reply
Hey ICE,
Any way you would be willing to send me a template for that wind dam so I could bring it to my local plastics company to make a plexi piece. Love what you did there. let me know
Thanks
Nic
Old     (joesell)      Join Date: Apr 2001       04-22-2010, 4:57 PM Reply
Ice, I'll let you know for sure. Thank's again!
Nic, Call Danny at Heatercraft 208-687-4400. He's super cool, and will take care of you for sure.
Ice and Nic, I wish I had a template too! that wind dam was a pain in the rear to cut out.
Old     (younguns44)      Join Date: Jan 2010       04-22-2010, 7:08 PM Reply
looks awesome nice work
Old     (_vitty_)      Join Date: Jul 2009       04-22-2010, 8:06 PM Reply
Thanks Joe!
I installed the panel this evening after work along with the 4 wet sounds in it. Man what a pain in the ass that was. Looks awesome though now that it's on and the speakers are in. I will take some pictures tomorrow. It got too dark by the time I finished.
Old     (usostyle)      Join Date: Apr 2006       04-22-2010, 9:39 PM Reply
Nic-
I'll take measurements of the plexi tomorrow or saturday and send it to you. Are you going to get the channeling from scott @ samson sports? If so, I will measure it as if you do not need those notch cutouts on the bottom of the glass like mine. If I was to install the wind dam again, I would not use the black plastic stoppers on the bottom of the channeling. I had Scott send me the plastic rounded stoppers so people wouldn't catch or snag the bottom of the channeling when they walked through the walkthru. However, after seeing how Scott fabbed the top of the channeling, it is angled and smooth enough to where if I would have had him do the same smooth angle on the bottom, it would eliminate the need for the black stoppers. This way, your plexi doesnt have to have those little notches on the bottom and will prob save you $ on the plexi fab labor. I would just have scott make each end of the channeling angled and smooth instead of using the black plastic stoppers on the bottom. Does that make sense?
Old     (dachbr)      Join Date: Aug 2005       04-23-2010, 2:51 AM Reply
Nice work Nic. I used the same procedure when I removed the 8 Clarions and Installed the 10 Inch HLCD NVS Addictions in our Epic. I also changed the Clarion transom amp to a Tru-Technology. We put over 100 hours on it last year and it works great. With our pre-Kicker system there is an 11 inch space from the speaker to the speaker cover (which I added a plastic mesh on the inside) so water to the speaker has not been a problem for us "YET".
A few other things we've done; Our boat was an early '08 with a rough dull gelcoat. I spent a lot of time removing the factory graphics, wetsanding and adding good ole' redneck tribal graphics.
I added a grab rail for the swim platform and a tow hook. We do slalom behind this boat and the 8.1 can pull a bunch of tubes.
Lastly I added trailer frame extensions to assist with getting in and out of the boat when on the trailer.
Great thread with lots of mods I plan to do!
Old     (_vitty_)      Join Date: Jul 2009       04-23-2010, 6:26 AM Reply
Thanks Dale! Your boat is looking awesome. I really like that tow hook you put in the back for tubers. You should snap a picture of what you did inside the hull for that.
Here is a quick phone snapshot of the plate installed on the transom from last night.
Old     (usostyle)      Join Date: Apr 2006       04-23-2010, 6:46 AM Reply
Dale-
Great work! We are actually in the infant stages of making an assist step as well. I love what you did with yours, how does it work for you? Attached is a pic of a metal plate that we fabbed. We were thinking to make it removable with a pull pin and maybe mount it to the outside or front of the guide pole. LIke I said though, very early stages. I really like the ones you did, functional? is it wide enough that people don't slip on it or fold their sandals over it when they step up? Any things would do different if you were to do it again?
Here are some pics of our step, very 'rough' stages, obviously if we ended up using it, we would powder the top red and use black grip tape on top and etch out the Epic emblem so the step was all black with Epic in red (like the Epic emblem on the Pacific trailers).
Old     (usostyle)      Join Date: Apr 2006       04-23-2010, 6:47 AM Reply
Nic-
Nicely done!
Old     (olmoomba)      Join Date: Apr 2010       04-23-2010, 1:11 PM Reply
Alrighty Joe, I'm here and very impressed with the mods everyone is doing.
Here's what I have guys and I need to know your interest. I am working with a couple of manufacturers right now on getting some things completed that will benefit us.
1. gunnel pads - I have measured and completed a cad drawing for the ginormous gunnels we have and all I have to do is buy it. I had templates but I don't think they survived our latest hurricane here on the gulf coast. I am willing to get them to make more templates but I would like to know who is interested so I can let them know as well. And I mean a serious interest. They are a good fit on my '07 but I will need to find an '09 owner to test the new templates.
2. Fold down swim platform bracket. I do believe we are past the initial design phase of this project and I am waiting to hear back on current progress. I hope to have a prototype ready very soon, again I am waiting to hear back. The idea will be that the swim platform will slide out and then fold down to make it easier to back into storage as well as provide more space in your storage unit/garage. I also need to justify to them to further this endeavor. Please let me know your interests by PM, I do not want to hijack this thread, unless you guys are ok with posting up here.
Glad to see I am not the only one trying to innovate and personalize the EPIC!
Fred
Old     (olmoomba)      Join Date: Apr 2010       04-23-2010, 1:13 PM Reply
Joe - I will take pics of the "T-handle" drain and post them up early next week, as well as the play pen cushion, and transom subwoofer boxes (when they are done)!
Old     (duffymahoney)      Join Date: Sep 2008       04-23-2010, 1:35 PM Reply
Dale,
How many 10inch nvs speakers do you have?
Old     (olmoomba)      Join Date: Apr 2010       04-23-2010, 1:39 PM Reply
Nic Vit's old speakers - thanks Nic! Yes, I still have holes to fill, you can see I used to have the grills on there and I still have to wet sand. BUT I do have those subwoofer eclosures I have built, pics on another camera, that will cover those tiny holes and led strip rust stains.
Old     (olmoomba)      Join Date: Apr 2010       04-23-2010, 1:41 PM Reply
1 more pic of the graphic - with the exception of the banner, both sides are different as we put these on seperately in a collage fashion.
Old    ScottRobinson            04-23-2010, 2:31 PM Reply
Guys, nice I read this everyday and get pumped to get my 2011. Just wired money today to EPIC. Black hull, and also they are putting on the FAE for me. I had to order it but shipped to them and they are putting it on. So, that will be done. I will want the best solution for the WIND DAM, so whoever is doing that let me know. Also Fred, I have black hull coming and want to put my own version of wrap on it. So, is what you have from the factory? or did you do that? If you did, is it going to be easy to take off the factory stickers? Or should I have them just not put them on? Oh...one BIG thing!! Has anyone thought of a swim step of the platform that tucks up under the platform with a latch? I have 4 small kids and not sure they can get on without a ladder type thing, even if it is one step...thoughts on how to do that or has someone tackled that? Thanks guys, May 20 is the date for me guys, can't wait to show you all.
Thanks for all the ideas, Joe and Ice....
Old     (joesell)      Join Date: Apr 2001       04-23-2010, 3:32 PM Reply
Scott, I took some pic's of the interior for ya.
Old    ScottRobinson            04-23-2010, 3:44 PM Reply
Thanks brother, they have offered me to change the interior but I just can't see how. I have black hull, but want black inside, but have no idea how to? Thought about making the grey black, but I just think that it will get just too dang hot. Guess I am just going with stock interior, but I am wanting to change outside graphic. So, may not have them put them on.
Old     (joesell)      Join Date: Apr 2001       04-23-2010, 4:36 PM Reply
Make sure they send the graphic with, even if they don't put it on. That way you at least have it for when your wrap wears out.
Old    ScottRobinson            04-23-2010, 5:56 PM Reply
Yes great point....
Old     (_vitty_)      Join Date: Jul 2009       04-23-2010, 7:56 PM Reply
Lookin good Fred! I bet that sounds pretty nice now!
Joe, man you got that boat sparkling!
Old     (_vitty_)      Join Date: Jul 2009       04-23-2010, 7:57 PM Reply
Here is a quick snapshot of the transom with all the speakers in it
Old     (dachbr)      Join Date: Aug 2005       04-23-2010, 10:53 PM Reply
Wow; looks nice and clean Nic. I will get a pic of the tow mount when I get a chance but I can tell you it is thru bolted to an 18 inch long piece of HEAVY aluminum angle. If it pulls off the transom is coming with it!
Ice, your steps will certainly be the deluxe model! My first attempt was to have a local trailer mfg fabricate steps made of angle iron and expanded metal. They really did not extend far enough back to be useful and looked like crap so I scrapped them. I then searched around my shop and came up with that material. (don't turn me into OSHA but they are made from the rollbar that I removed from our new Kubota tractor ) I had intended to add a nonslip surface but it really has not been needed. We've had them on for a year and loaded a bunch of folks including kids and they have worked perfectly.
Duffy; We have a pair of the 10 inch HLCD speakers mounted in the transom. There really is only room for one on each side but it has been more than enough to get the attention of the local water patrol officers. I really need to add the FAE so we can back it off a bit.
Old     (joesell)      Join Date: Apr 2001       04-24-2010, 2:30 PM Reply
We were talking about the cooler issue. I thought a thru-hull drain in the bottom of the boat would be the best solution, but I think we were all worried that it might void our hull warranty. I e-mailed Jason at Epic just to be sure. Just like every other time I've had contact with anyone at Epic, I got an immediate response. He said I could install a drain and NOT void the hull warranty. However, he cautioned that the fuel tank was directly behind the the cooler, and if I somehow drilled into that, it wouldn't be covered.
So I went to the local marine parts store to find a v shaped thru-hull to install. They didn't have one. If I can't find one soon, I think I'm going to ask my buddy to make me one.
I also had a setback with the heater. I ran the boat in the driveway for an hour. I had the temp guage up there, but no heat out of the second heater. Even if I ran it up to 2000 rpm, no heat. So I'll be installing a pump into the system this weekend. I'll let you know how it goes.
Old     (joesell)      Join Date: Apr 2001       04-24-2010, 2:35 PM Reply
Ice, I'm still interested in those steps. They look pretty nice man.
Fred, glad to see you made it on here. You have a lot of cool ideas going on. Good job on the speaker swap. I can't wait to see the sub boxes.
Nic, That panel turned out sweet. The spacing turned out perfect. I like the remote spot too. Way, way better then trying to squeeze it in the middle.
Old     (joesell)      Join Date: Apr 2001       04-24-2010, 4:25 PM Reply
Ice, I got the stickers, and the decal today. Thank's a lot buddy. I might have to swap the white one on the tower for one of these orange one's.
Old     (usostyle)      Join Date: Apr 2006       04-24-2010, 10:10 PM Reply
Scott-
As far as the wind dam, if you end up going the route I did, I have a template traced and ready to send to you if you want it, just pay the shipping. I traced one out for Nic and thought I'd trace you one just in case. Let me know.
Joe-
Great info on drain, I am going to be in pursuit of a through hole drain as well, probably have my dealer do all the work though. The idea of me punching a hole through the lowest point of my boat, right next to 50 gallons of 91 grade is a recipe for disaster! Bummer about the heater, but knowing you, it's probably already fixed. Glad you got the emblem and stickers all in one piece.
Dale-
I am liking your step better than what we have going. Especially since- 1. It's more permanent, and out of the way. 2. It's and tried and true & you have had no issues and it has worked great for you guys. Why re-invent the wheel? I may be jacking your idea and copying you...
Nic-
Sent you a PM, let me know your address, your template is ready to go.
Old     (dachbr)      Join Date: Aug 2005       04-25-2010, 12:41 AM Reply
Ice; When you said you might have your dealer do the cooler drain in your boat would that be Tyrell at Prestige? I like that idea as well and Tyrell is a great guy but I don't want to make that 3,253 mile round trip again so................
Joe; When you do yours please take plenty of pics to go with the detailed instructions.
Old     (_vitty_)      Join Date: Jul 2009       04-25-2010, 7:42 AM Reply
Got my sub box finished minus carpet last night. It's going up under the driver's feet area. I removed the plastic heater panel. I should still have plenty of room to stretch my legs fully out without hitting the box.
Old     (_vitty_)      Join Date: Jul 2009       04-25-2010, 10:18 AM Reply
Also, has anyone ordered any carpet for our boats? I need to carpet the above box but can't find anything local.
Old    ScottRobinson            04-25-2010, 12:43 PM Reply
Yes for sure I want that ICE. I will be out of town next week but I will send you an email the following week for it. Also, did you get your channelling from the guy above? I want to find that smoked look, but figure I will just get it tinted after its done right? Has anyone thought about the 2 other ideas I thought of?
Ladder for getting onto the swim platform for kids?
or
Bow filler cushion?
Old     (joesell)      Join Date: Apr 2001       04-25-2010, 4:57 PM Reply
Ice, the heater fix is going to be done tomorrow. Thanks for the vote of confidence.
Dale, I'll take some pic's for sure. I've already taken more pic's of this project then all my other projects together.
Nic, how did the bilge go today?
Scott, I'd like a bow filler for sure. I haven't figured out how to support it yet. I talked to a vinyl guy here, and he said he could make me a cushion no prob.
As far as the swim ladder goes, I'll have to see how hard it is for my 5 year old to get in. Him and his brother did pretty good on my last boat. Besides, You might not be able to fit it in there now that your getting an FAE.
Old    ScottRobinson            04-25-2010, 5:13 PM Reply
True Joe.....
I know I will want a filler so I have to see when it gets here how to support it. Have you had any thoughts on that? As far as the ladder goes, you may be right. My boat is coming from the factory with FAE already on it. Darn...hmmmm Yeah my wife will kill me if I bought a boat my 4 year old can't get back into...lol My 6 and 8 will be find but the 4 and 2 won't for sure. So, guess I am going to have to wait and see it when it shows up. I do want the filler tho, so give that some thought since you are the guru along with ICE. Between you two, you have solved just about everything.
Oh, and what is that stuff called that I have to spray around everything so the bass doesn't shake everything? And where do I spray it?
Old     (joesell)      Join Date: Apr 2001       04-25-2010, 6:08 PM Reply
Scott, You need dynamat. Look on e-bay. Get the sheets, I think its better then the spray. Your going to have to take the whole right side of the boat apart to get it in there though.
Nic, the box looks great! Where's the heater hole?
