Old    JKW (watersun)      Join Date: Jun 2009       02-19-2010, 11:02 AM Reply
This will probably start a war, but what good sounding tower speaker out there has the lowest profile when mounted on the tower? I have a 2008 SAN 210 with the titan tower and it sits kind of low. And no, I don't want to mount them above the tower as I'm not a big fan of that look. Also, when I say good sounding, I mean I want them to be clear riding at 80'+...I'm not so concerned about the sound inside the boat.
I've heard of NVS, Wetsounds and Exile. Which of these have the lowest profile? Are there any other brands out there you would recommend? Thanks a lot!
Old    Who Cares (liljohn)      Join Date: May 2007       02-19-2010, 11:15 AM Reply
Bullets!
Old    M-Dizzle (liquidmx)      Join Date: Jun 2005       02-19-2010, 12:02 PM Reply
I think one of the NVS versions is a 10" speaker with like an 8" footprint or something. Where the housing literally wraps around the tower mounting point. I think its the Modus and Prodigy.
Old    TigeMike (chpthril)      Join Date: Oct 2007       02-19-2010, 12:57 PM Reply
The New Kicker KM6500.2 are a 4-can setup that will fit most enclosures that accept a 6.5 speaker.
http://www.kicker.com/km65002
I'm hoping they will be shipping in the next few weeks.
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       02-19-2010, 1:00 PM Reply
You can always mount them on top of the tower.
Old    Brian (brianinpdx)      Join Date: Aug 2009       02-19-2010, 1:14 PM Reply
JKW - no, this thread shouldn't start a war. Your asking for pretty straight forward information. On the Titan tower, you'd use our universal clamp and the total hang height is just under 9 inches and you can spin the speakers (literally)in 360 degrees and have a 100% pass through audio connection - no flying wires of any kind.
For guys that can go with our direct fit clamp, it chops the hang height down to 7.1 inches. Just to be clear, that would not work on your tower setup.
Have a good weekend,
-Brian
Exile Audio
Old    Brett Yates (polarbill)      Join Date: Jun 2003       02-19-2010, 1:25 PM Reply
Here is what M-Dizzle was talking about. 8.6" hang from a true 10" speaker.
http://www.nvs1.net/prodigy.html
http://www.nvs1.net/modus.html
http://www.nvs1.net/deviant.html
Old    David_E_M Earmark Marine (david_e_m)      Join Date: Jul 2008       02-19-2010, 3:26 PM Reply
JKW,
If minimum hang height is your primary goal, the Bullet HollowPoint 770 HLCD has a maximum hang height of only 8 3/4". And, you'll get a 7.7-inch midbass driver which means good midbass, in this low profile package. Typcially the hang height of 6 1/2-inch HLCDs is around 9 1/2" with a universal collar on a 1 7/8" thick tower.
The NVS is truely a shallow mount too.
Keep in mind that the power requirements of a 10" NVS is going to be completely different than those of a smaller driver. So, don't select a speaker without considering this also. The midbass on a Prodigy will crack you like a whip (and that's a good thing) but they want 500 watts a side to reach their potential. Just make an informed decision.
David
Earmark Marine
Old    Mikeski (mikeski)      Join Date: Aug 2003       02-19-2010, 11:30 PM Reply
might want to look into the 6x9s that wetsounds are coming out with in April?
