I have an 07 210 Team, Love it. I ride stock plus the following set up: 600lbs of lead in he bow 440 sac's on each side of the engine 2 75 lbs bars midship on each side 23.2mph @ 75, or 24mph @ 80 3-6 people in the boat Like Shaun said, and if you miss the vertical lip/kick of the old SAN hull, just add more weight to the stern and you're set! It's a great hull, and IMO one of the only you can truly tailor the wake to your liking depending on weight placement. *just make sure you get/have the power prop or one similar in size and you're set. Transition is much wider than the old hull, and the trough is a little deeper. Mostly ridden behind SAN's, but I really like a loaded MC X1 and loaded VLX -but with both I was always disappointed with the thickness of the wake and kick (lip), the 07 + SAN hull doesn't lack these at all. Every single person that rides behind my boat finishes up their set with a huge smile and usually a "wow", and loves it...don't listen to anyone else though, go demo one. Good luck!
