Old    Matt (pierce_bronkite)      Join Date: Jul 2003       08-06-2003, 11:58 AM Reply
I have a 2001 Tige 23V and the stearing is stiff both ways. Does anyone know if I can fix this myself? Is there something that I can grease? Or does anyone know if there is such thing as power steering on these boats? Any suggestions?
(Message edited by Pierce Bronkite on August 06, 2003)
Old    Chaun Keating (big_poppa_pump)      Join Date: Apr 2002       08-06-2003, 12:20 PM Reply
Pierce,
There should be grease fittings on the inside of the hull right on the rudder and on the rudder end of your cable. Smearing a tiny bit of grease along the cable shaft (that connects up to the rudder) is not a bad idea either.
If that does not cure your problem, then you are probably due for a steering cable change. I believe the insides of the cable are teflon coated and not really "greaseable" and so must be replaced when the teflon is worn.
Old    xtigeman            08-06-2003, 9:42 PM Reply
Sink it while you are ahead.
Old    Cory Sellers (jaxboarder)      Join Date: Dec 2001       08-06-2003, 10:00 PM Reply
easy now big boy... mine had the same problem, it was from not lifting the boat high enough and the bottom of the hull sat in the water at high tide corroding the rudder, my dad kicked it and it solved the problem...probly not the best choice but it worked.
Old    xtigeman            08-06-2003, 10:32 PM Reply
Maybe I shoul just have kicked mine harder. Huh. That might have worked.
Old    Cory Sellers (jaxboarder)      Join Date: Dec 2001       08-07-2003, 9:49 AM Reply
maybe so... ive done my fair share of kickin the derned thing... when its working its a great boat, and most of the problems ive had were from this being the our first ski boat and nobody knowing how to take care of it.
Old    Brent H (captainfreedom)      Join Date: Apr 2002       08-07-2003, 10:16 AM Reply
Doug...such maturity from your post. Have you been hanging out on the other board lately? That is the kind of response I would expect to find there, but not here.
Old    Matt (pierce_bronkite)      Join Date: Jul 2003       08-07-2003, 11:57 AM Reply
Thank you Brent. Enough said.
Old    sandman            08-07-2003, 2:33 PM Reply
Anyone followng this board the past couple of monts would know there have been more late model MC's with steering cable issues than Tige's.
Old    xtigeman            08-07-2003, 6:42 PM Reply
No one has a sense of humor any more. Going to kick my Porsche so maybe I can get that damn strut bar in tonight.
Old    Cory Sellers (jaxboarder)      Join Date: Dec 2001       08-07-2003, 9:15 PM Reply
worked on the jeep
Old    tige_joe            08-07-2003, 11:41 PM Reply
I don't think it's the "no sense of humor"......maybe it's just the tireless pokes and jabs of the same few people. Sorry, Doug.
