Old    Dave (bcrider)      Join Date: Apr 2006       02-12-2010, 4:58 PM Reply
I am looking to install all the plumbing for a some Fly High Side sacs ( 260lbs each) and was wondering if it is worth the extra $$ to use 1" over 3/4" lines/fittings as well the upgrade to a 1200gph pump over a 800 gph pump with the larger lines. I understand the larger lines and pumps will move more water but would like to know on 2 sacs how much of a difference would it really make? Anyone have an idea what the fill time differences would be? Wondering if it's worth the extra coin?
Thanks
Old    Dave (bcrider)      Join Date: Apr 2006       02-13-2010, 12:18 PM Reply
seriously...nobody can answer this?
Old    Matt Foell (vr6mole)      Join Date: Feb 2009       02-13-2010, 1:06 PM Reply
test were done hooked up to a car battery and we were pumping water from a keg tub into a fly high sac.
Tsunami 1200 pump took 58 seconds with 3/4 inlet and 1 inch outlet
T800 was 2 minutes using 3/4 inlet/outlet
Tsunami 1200 with 1 1/8 hose (fly high kit) was 49 seconds
Rule 1100 with 1 inch hose and 3/4 inlet was 1 minute and 10 seconds
