Old    Curt Bowman (curt489)      Join Date: Feb 2008       02-11-2010, 2:20 PM Reply
How many thru hull fittings is alot for ballast system. I am re plumbing my ballast system so that when emptying it goes over the side rather than back through the bottom of the boat. I have a reversible pump system.
Right now i have 3 vent holes for the bags,and 1 for the bilge pump all on one side of the boat. I plan on adding two more thru hull fittings on both sides so that when emptying the water out of the bags it shoots over both sides. This would be 5 on the strb side and 1 on the port side.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       02-11-2010, 2:31 PM Reply
Just T into your vent lines and place check valves on the vent side and emptying side of the T.
If you don't want to put anymore holes in your boat.
Old    D C (dirwoody)      Join Date: Apr 2003       02-11-2010, 3:02 PM Reply
A good friend of mine has 4 vent holes (middle, front, and 2 rear) and 4 drain holes
Old    Nick in the TC (nick_in_ssp)      Join Date: Aug 2006       02-11-2010, 6:02 PM Reply
I have my vent and drain lines together without a check valve. Just make sure the drain lines goes straight out the boat and the vent is above the drain line.
