Old    Jay (jay_g)      Join Date: Apr 2006       02-10-2010, 12:08 PM Reply
Getting ready to pull the trigger on some Strandwoven Bamboo floors. I have narrowed it down to two options. The first is like any other laminated click lock (4mm of bamboo on 5 layers of plywood), The other is 3MM of bamboo on a HDF core. The HDF is $1.00 cheaper and @ 1200 sf thats a big savings. Anyone ever work with HDF core flooring?
Old    Jagermaster (jaegermaster)      Join Date: Sep 2002       02-10-2010, 12:56 PM Reply
Yep, that is what I used. I thought it was easier to do the harder pieces like in closets and around door jambs because you can shave the tongue of the piece with a razor knife, then glue them down. Some of the pieces are kind of hard to get together in tight areas.
I have a tap block and a metal pull bar that helps click the pieces together when you get close to a wall. If you want them I can send them to you. PM me your address if you want them.
Old    Jay (jay_g)      Join Date: Apr 2006       02-11-2010, 7:45 AM Reply
Jae Thanks for the offer thats real cool....Though I bought the tools last month so maybe another WW'er can use them. Have any pics of your work?
