Easy to wire up a front harness to just release brakes. Get a car side (mostly female) 5 flat plug, ground the ground wire (the one that has an exposed contact on the gar side plug), and hook the blue wire to 12v (battery. If you want the running lights on (basically to help light up the area you are driving into), hook all the wires besides the ground to 12v. This will keep the lights on whenever its plugged in. If you want it on with the ign, you need to find a 12v ign source.
