Old    WAKEMAKER01 (wakemaker01)      Join Date: Mar 2009       02-04-2010, 1:20 PM Reply
what is a good replacement for tige handle talked to my local dealer and thay want $975.00 that just parts plus $75.00 labor hr to replace there has to be aftermarket parts that are just as good?
Old    Nacho (denverd1)      Join Date: May 2004       02-04-2010, 1:26 PM Reply
skidim.com
IIRC think Morse shifter/throttle is the most common. Don't get bent over at the dealership "tige". They're not cheap, but they're damn sure not 1000.
Old    Razzman (razzman)      Join Date: Dec 2006       02-04-2010, 2:07 PM Reply
Well make sure first you know what it is. Is it cable or dbw operated? Drive by wire units are more, not sure they're $975 though.
Old    WAKEMAKER01 (wakemaker01)      Join Date: Mar 2009       02-04-2010, 3:28 PM Reply
its a cable and has the taps switch built into it .
Old    Brett Yates (polarbill)      Join Date: Jun 2003       02-04-2010, 3:33 PM Reply
The taps switch may screw things up. I wonder if it is worth just putting in a regular morse throttle and remote locating a rocker switch for the hydraulic plate?
Old    WAKEMAKER01 (wakemaker01)      Join Date: Mar 2009       02-04-2010, 4:39 PM Reply
thats what i was thinking i have a shower rocker switch on dash but no shower that should work?
Old    Brent (bfnaci)      Join Date: Dec 2008       02-04-2010, 6:06 PM Reply
Brett
Got any pics of the wake behind that boat on your profile?
Its got to be enormous...
Old    dhcomp (dhcomp)      Join Date: Jun 2003       02-05-2010, 8:03 AM Reply
Shower rocker won't work, because you need to be able to go up/town. You need a 3-way rocker. If you know your way around 12v though, you could make a Hi/off/low heater switch work.
Old    Nacho (denverd1)      Join Date: May 2004       02-05-2010, 8:18 AM Reply
ummmm... why not just but 3 position switch and stick it in the dash??
Old    Brett Yates (polarbill)      Join Date: Jun 2003       02-05-2010, 10:05 AM Reply
Brent, no. It is actually my dad's boat but I am hoping to get out this summer and try some surfing behind it.
Old    JUST-IN-TIME (justintime)      Join Date: Mar 2009       02-07-2010, 2:46 PM Reply
what happened to it?
Old    WAKEMAKER01 (wakemaker01)      Join Date: Mar 2009       02-07-2010, 6:51 PM Reply
? it was that way when i bought the boat.
