Old    swass            02-03-2010, 7:36 AM Reply
Oh great and wise photograhpy gurus: I'm having a problem with my telephoto lens. The camera body (D40) doesn't seem to recognize the lens. No shutter, no focus, no display - nothing. My standard lens works fine.
Is there room for operator error here, or is there something wrong with the lens?
Old    Scott (scott_a)      Join Date: Dec 2002       02-03-2010, 12:29 PM Reply
What lens is it?
Old    swass            02-03-2010, 12:42 PM Reply
I was afraid someone would ask that. I don't know - I'll have to get back to you on that one.
Old    Randy Scagliotti (wakedad33)      Join Date: Oct 2005       02-03-2010, 3:41 PM Reply
D-40, that's a Nikon body right, has the lens work with that body before and this problem just started?
Old    Rich Dykmans (richd)      Join Date: Oct 2003       02-03-2010, 7:49 PM Reply
Check the contacts on the lens, they may need cleaned.
Old    Craig F (craig_f)      Join Date: Feb 2008       02-03-2010, 8:39 PM Reply
is the aperture ring locked on the smallest setting? (if it is a modern lens w/o a ring, disregard this)
Old    swass            02-04-2010, 5:24 AM Reply
Yes, Nikon body and Nikkor 55-200 1:4 - 5.6 lens. It worked just fine before. It hasn't been dropped or anything. Everything seems to look clean.
(Message edited by swass on February 04, 2010)
Old    Jared L. (ladiii08)      Join Date: Mar 2009       02-04-2010, 6:09 AM Reply
The reason is because the lower models of nikon like the D40 and D60 do not work with a lot of the newer lens. if you look at a lot of the lens online, it will say that it does not work with the D40 or D60 usually, thats what ive seen.
Old    swass            02-04-2010, 7:10 AM Reply
That sounds reasonable...except the lens worked fine on the same body before.
Old    Jared L. (ladiii08)      Join Date: Mar 2009       02-04-2010, 7:51 AM Reply
hmm, thats weird, ive just seen that on some of the lenses ive looked at because of the smaller bodies that the D40 and D60 have.
Old    Nate (mammoth)      Join Date: Apr 2005       02-04-2010, 9:36 AM Reply
This is not true. Non AF-S lenses will still work on the D40 and D60, they just will not autofocus. Swass has a different problem going on here.
Double check those contacts and the aperture ring as mentioned above. Have you swapped on a different lens to make sure you don't have something non-lens related going on? We've all been guilty of thing like missing SD cards or having a setting wrong that won't let the camera work.
Old    Jared L. (ladiii08)      Join Date: Mar 2009       02-04-2010, 11:38 AM Reply
my bad, i went back and checked, and it says on 'most of the lenses'--- ". AF not supported by D40 and D60 cameras. "
Old    swass            02-04-2010, 6:37 PM Reply
I took it to a camera shop. It didn't work on another D40 body either. It'll cost almost as much to fix it as it would to replace it. Any suggestions on a replacement?
Old    swass            02-05-2010, 9:00 AM Reply
Something tells me I have worn out my WW welcome.
Old    Randy Scagliotti (wakedad33)      Join Date: Oct 2005       02-05-2010, 10:21 AM Reply
Swass, I'm a Canon shooter so I can't help. Sorry.
Old    A. P. (bigdad)      Join Date: Apr 2002       02-05-2010, 11:21 AM Reply
Nah Swass, I still like you. What is your price range and what are you looking to do with it.? Asking what lens to buy is like saying what car do I buy? So many different options.
Old    A. P. (bigdad)      Join Date: Apr 2002       02-05-2010, 11:28 AM Reply
The D40 is the lower end of DSLRs. Although a very capable camera it does have its limitations. Not to say great pictures can't be taken with it but that body with a cheap lens won't get the same results as some people on this forum. However, a lot of photography has more to do with the person behind the lens as opposed to the equipment.
With that being said, how about a all in one walk around lens. It may look a little big on the D40 body but this is a lens you can use anywhere.
Tamron 18-270 f/3.5-6.3. Again it has it's limitations but is compatible with your camera and will leave you satisfied until you feel the urge to upgrade your camera and start dropping thousands of dollars on this hobby. Check the reviews out for yourself and see how good it is. I like Tamron. Although I don't have this one, all my "pro" lenses are Tamron.
http://www.bhphotovideo.com/c/product/581247-REG/Tamron_AFB003NII_700_18_270mm_f_3_5_6_3_Di_II_VC.h tml
Old    swass            02-05-2010, 12:17 PM Reply
That's good to hear, A.P.
Thank you for the advice. I'd like one comparable to the one that's broken (in the same price range). I don't see any point in going with a Nikkor lens again, so I'll look at Tamron.
Old    A. P. (bigdad)      Join Date: Apr 2002       02-05-2010, 1:04 PM Reply
The 55-200 only goes for $170. Not to sound crass but at that price range, just pick whatever. Glass that cheap is mediocre at best.
With lenses, you really get what you pay for. The lens is WAY more important than the camera body. A great lens on a cheap body will give you great results. A cheap lens on a great body will give you garbage.
Old    Craig F (craig_f)      Join Date: Feb 2008       02-05-2010, 5:27 PM Reply
should be a 5 year warranty on the lens (unless it is gray market) check to see if it says "us" before the serial number. If it is under warranty, ship the thing off for repair! I personally can't justify the sigma/tamrron lenses . in this price range because they are not any better made, and you don't end up saving all that much money.
Old    swass            02-05-2010, 5:28 PM Reply
I hear ya. Thanks, A.P.
Old    Randy Scagliotti (wakedad33)      Join Date: Oct 2005       02-05-2010, 6:21 PM Reply
+1 for the Tammy glass, most of my stuff is Canon L, but I do own a Tamron 17-50 2.8 and love it, very sharp.
I 2nd what AP said,
"A great lens on a cheap body will give you great results. A cheap lens on a great body will give you garbage".
True dat.
Old    Randy Scagliotti (wakedad33)      Join Date: Oct 2005       02-05-2010, 6:44 PM Reply
Swass, have you checked out Fred Miranda, you might pick up a good used lens at a good price. Great place to buy used gear.
http://www.fredmiranda.com/forum/board/10/1
Old    A. P. (bigdad)      Join Date: Apr 2002       02-05-2010, 7:52 PM Reply
Ok Swass, if you only want to spend a couple hundred bucks, take a look at this one.
http://www.bhphotovideo.com/c/product/550952-REG/Tamron_AF014NII_700_18_200mm_f_3_5_6_3_XR_Di_II.ht ml
With the rebate it is only $230. Again, don't expect miracles and at times you may get frustrated but it will suit all your needs and in the end be happy.
Old    swass            02-08-2010, 6:33 AM Reply
I'm a casual photographer, at best. I'm sure that one would be more than adequate. Thanks again for the help.
Old    Chris            03-15-2010, 7:39 AM Reply
A.P.,
I took your advice and ordered this lens. It should be here today. I appreciate the help.
Old    Chris            03-16-2010, 7:30 AM Reply
Two thumbs up!
Old    A. P. (bigdad)      Join Date: Apr 2002       03-16-2010, 8:43 AM Reply
Which one did you go with?
Old    Chris            03-16-2010, 9:29 AM Reply
The second Tamron that you recommended. I like it much better than the Nikkor it replaced.
Moochos grassyass.
