Old     (thesack)      Join Date: Mar 2008       01-30-2010, 11:54 AM Reply
I installed a new pump to fill the front sac on my 2007 Supra Launch 21V. Spliced the wires to the solenoid wires, changed the fuse under the helm, disconnected the wire for the other old pump at the switch. Took the boat out on the water to test everything to make sure it worked right. Flipped the switch and everything turned on. Let the sac fill for a while then turned it off. Then went to turn it back on and the new pump did not turn on. The indicator light for filling did not turn on either. Checked to see if i blew a fuse, or if the connection by the fuse came undone. Neither had happened. Flip the switch to drain, the drain pump turns on but the indicator light does not turn on. Get the boat home and take things apart. When turning the switch on i have no power going to the solenoid prong on the switch, but i have power going to the old pump prong. Switched the wire connection to from the solenoid prong to the old pump prong. New pump turned on, but still no indicator light. I am assuming that my switch is faulty and needs to be replaced. But wanted to see if there is anything else i should look for or if anyone else has had this problem.
Old     (spencerwm)      Join Date: Feb 2009       02-02-2010, 9:19 AM Reply
Did the new switch fix the problem?
Old     (thesack)      Join Date: Mar 2008       02-02-2010, 10:36 AM Reply
Yep the new switch fixed the problem.
