Just curious if any of you who have PSS dripless shaft seals ever see a stream of water running down the prop shaft when you flush your boat on the trailer. I know that there is water directed to the seal for lubrication (tee off the main raw water line, I believe), but I wasn't sure if I should be seeing a lot, a little, or none at all. I ran the SAN in the driveway for a few minutes this past weekend (~800 RPM's in neutral) and saw water coming out of the area where the shaft goes through the hull into the seal. Any insight is appreciated...thanks!
