Old    Tony Medaglia (h2ohangtime)      Join Date: Aug 2002       01-25-2010, 6:40 PM Reply
Just curious if any of you who have PSS dripless shaft seals ever see a stream of water running down the prop shaft when you flush your boat on the trailer. I know that there is water directed to the seal for lubrication (tee off the main raw water line, I believe), but I wasn't sure if I should be seeing a lot, a little, or none at all. I ran the SAN in the driveway for a few minutes this past weekend (~800 RPM's in neutral) and saw water coming out of the area where the shaft goes through the hull into the seal. Any insight is appreciated...thanks!
Old    Harold Hemming (h20king)      Join Date: Dec 2009       01-25-2010, 8:32 PM Reply
it,s normal you should see water. as rpm's increase so will flow
Old    Tony Medaglia (h2ohangtime)      Join Date: Aug 2002       01-25-2010, 10:30 PM Reply
Thanks Harold, I figured that was the case but just wanted to be sure.
