Old     (colombiansurfer)      Join Date: Sep 2008       01-22-2010, 4:16 PM Reply
Just wondering if the digital amps, like Alpine PDX and Arc's XXD are any better than say the Wetsounds, Kicker and Exile Amps. Is there really a difference that can be heard in a boat or in open area? The digital amps seem to be all the same size and stackable vs, the regular amps. Is digital amp the new "Thing" or the "Future"? Sorry if this sounds stupid, but just wondering.
Old     (shawndoggy)      Join Date: Nov 2009       01-22-2010, 6:08 PM Reply
class d amps are more efficient, so they draw less current to make the same watts. On a boat that's nice because that means your battery lasts longer.
Old     (mikeski)      Join Date: Aug 2003       01-22-2010, 7:07 PM Reply
I have been running Tripath class D and other Class D full range amps for years. The Tripath stuff seems to be gone but I just picked up a little Clarion Kappa 5 for my car. I am very happy with the amps performance. It is the third amp in my car and really outperforms the two other previous class A/B amps. The highs really came to life with this amp and it does very well down low too. The tiny footprint is a huge plus.
http://signature.crutchfield.com/S-FjSTtiF8dPJ/s_108KAPPA5V/Infinity-Kappa-Five.html
Alpine PDX amps get consistenly good reviews. Not sure about the Arc XXDs, of course Wetsounds seem to be the standard to compare against. Exile... don't even get me started on that topic. All I will say about them is don't believe the hype.
Keep in mind many stage systems are using class D amps. Many audiophiles are using class D now too. In my opinion class D IS THE FUTURE.
Old     (chpthril)      Join Date: Oct 2007       01-22-2010, 7:16 PM Reply
Kicker just released a lineup of Class D amps as well. Check out the new IX and Dx series.
http://www.kicker.com/ix_amplifiers
Old     (bingbing)      Join Date: Oct 2008       01-23-2010, 12:15 PM Reply
Mikeski is right!! The class D IS THE FUTURE. I've been a big proponent of A/B hi-end (Tru,Arc,Zapco and others). Quality amps like this run $1000+ retail. I've personally been running Tru amps in my boat for four years.
The last 3 months I've been testing, in my truck, a new full range class D amp made by ZED. 250X2@4 ohms 500X2@2 ohms Actual bench test 325@4 ohms 581@2. The first thing I noticed was the mids just popped and highs were smoother. The amp just rocks. It's one of the finest A/B or D amps I've listen too. The best part is the price $449 retail. They make 6 channel 150X6@4 ohms and 300X6@2 ohms $599. This will make a great amp for the boat.They are currently working on 4 channel mono amps.
Small company, but the owner designer has is highly respected in the business. Has a history of making great products
www.zedaudiocorp.com/
Old     (colombiansurfer)      Join Date: Sep 2008       01-24-2010, 6:21 AM Reply
Tim (Wetsounds), are you guys looking at any Class D amps for the near future?
Old     (wake1823)      Join Date: Dec 2005       01-25-2010, 6:42 AM Reply
^^^ I'm pretty sure wetsounds amps are class G/H?? Typically a step forward form class D.
Old                01-25-2010, 7:48 AM Reply
You are correct...Class D is nothing new to market.
Old     (david_e_m)      Join Date: Jul 2008       01-25-2010, 8:31 AM Reply
Within several more seasons we'll be carrying nothing but Class D amplifiers, except at entry price points perhaps.
Of course, some future technology or outgrowth could displace Class D but in this industry and economy I don't see much new R&D. Besides Class D is coming down in price.
Also, JL Audio is introducing a more cost effective Class D line up that benefits from the trickle down of the HD amplifiers. Look for these around March-April.
BTW, Class D is not Digital. Its still an analog amplifier.
Like anything else, all Class D amplifiers are not created equal. Some of the cheaper Class Ds will be adequate for moderate in-boat systems but you'll have to step up to the more expensive series to properly drive tower speakers.
David
Earmark Marine
Old     (wetsounds1)      Join Date: Jan 2006       01-25-2010, 10:24 AM Reply
Pootie,
David is correct Class D is NOT digital. It stands for the class of the topology.
The Wet Sounds SYN amps use Class H and Class G/H. Class H and Class G/H, ARE switching amplifiers so they are very efficient. Like a Class D. They just achieve the efficiency in a different way.
So really what you are looking for in a boat application is efficiency. More power with less current draw. Which is Class H and Class G/H, full range Class D and Class D. All of these achieve the same end goal. But there are pros and cons to each.
Some of the other brands you mention are Class AB. Which is inefficient topology as compared to Class H, G/H and D.
Also, there have been Class D amps for years. I used them back in the old school car audio days. What you are referring to is the new Full Range Class D amps.
There are a lot of different amplifier topologies. http://en.wikipedia.org/wiki/Electronic_amplifier
Anyone who has a LOT of time and is interested in learning some more.
Let me try to explain them in real world terms so everyone can get a better understanding of the pros and cons of each.
In most 12 volt amplifiers, You will see Class AB, Class D, and Full Range Class D. Very few Class H and Class G/H. Even less true Class A and since Tripath is no longer around, even less Class T. (this was the one mikeski talked about, it is a version of a class D amp made by a company called Tripath, but since the company went out of business, you do not see any class T around anymore)
Class AB is the typical topology used in most 12 volt and many home amplifiers. It can provide a clean solid sound. But lacks efficiency. So it wastes a lot of current as heat as the power supply is at full voltage all the time. So you get a larger amp that needs a larger heat sink to dissipate the heat. It also pulls a lot of current and pulls that current all the time no matter the volume level.
Think of it as a car without a gas pedal. Only a brake. You turn the car on and it pegs redline. To go, you let off the brake and the car goes. But no matter what speed, it is at red line. And even when sitting at a light with your foot on the brake. The engine is at full red line. So obviously the car will run hotter and this is not an efficient way to run a car.
PROS: Good sound. Lots of power possible.
CONS: Inefficiency. So pulls lots of current. Larger in size as compared to a switching amp and runs very hot.
Switching amplifiers like Class H and Class G/H and Class D and full range Class D are called switching because the switch the voltage. Class D switches each of the output devices on and off. While Class H and Class G/H switches to different rails. It couples a class AB output stage with the rail switching to achieve the efficiency.
So you get the car with a gas pedal. You need more power, you stomp on the gas. At idle, the engine can sit there are run and run nice and smooth and not generate a lot of heat, power is then needed to go, push the gas and it goes, get to a cruising speed, engine will run nice and efficient.
Class D was originally used only as sub amps because of the distortion created by the switching on the high end. The newer ones are called Full Range Class D as they have circuits designed to compensate this problem on the upper end of the spectrum. There are different ways to do this and a few IC companies that make the chipsets for full range class D.
Class D:
PROS: Lots of power in small footprint and efficiency
CONS: Can only be used for subwoofer duty as there are sound quality issues on the upper end of the frequency spectrum.
Full Range Class D:
PROS: Small Size. Very Efficient. Low Heat.
CONS: Most of the IC's cannot produce as much power as a class AB or Class H so limited amount of power and sound quality is not up to par as class AB and Class H
Some can hear the difference. Some cannot. I can close my eyes and you could switch back and forth and I can tell you what class I am listening to. I am not a fan of the full range class D amps. (YET!) They are getting better and YES we have prototypes we are working on that are getting better with each version. Because of the market trends of smaller and more efficiency. More and more development and engineering time is being devoted to full range class d amps. So the sound quality is getting better and better every year. And the costs are getting lower. So we will have full range class d when I feel the amps can deliver the sound quality and high power I am after.
I agree with David that most are fine for in boats but lack the power needed for the tower. And with the sound quality not up to par. I do not like putting them on the towers, especially HLCD. Although we have many dealers and customers that do and love them.
So maybe I worry too much about the sound quality or maybe it is because I can hear every nuance. The best way for me to describe it. Is the difference between listening to a MP3 player and a CD. A MP3 is compressed. So it sounds like something is missing (because it is) Switch to a CD and the dynamics open up. Sound Stage opens up. So to me when I listen to a full range class d, I can hear the lack of dynamics as compared to a class H, G/H or AB. But in the end. Most people probably cannot hear those nuances.
But this is why we use Class H and G/H. It sounds like a Class AB so I get the sound quality and power with the efficiency of the Class D. So I feel it is the perfect topology. I get the best of both worlds.
Class H and G/H
PROS: Great Sound, lots of power and high efficiency
CONS: None with the exception that our version is a bit more money than some of the new entry level full range class D but still less than some of the other upper end full range class d.
Hope this helps! Best advice I can give is look for amps with efficient topology when shopping. And if you can get a demo. Listen to them. You may like the sound of one over the other. You may not hear a bit of difference. As everyone hears different. So get a demo. Always the best advice I can give when looking for audio gear.
Plus, getting a demo and listening is part of the fun or building a system!
Tim
Wet Sounds
(Message edited by wetsounds1 on January 25, 2010)
Old     (colombiansurfer)      Join Date: Sep 2008       01-25-2010, 6:20 PM Reply
WOW! Tim, thanks for the break down. I am still going to use your products; I was just asking because I didn't know.
Old                01-26-2010, 6:28 AM Reply
That is what the forum is for!!!
You can't go wrong with Wetsounds.
Old     (bjeremi)      Join Date: Mar 2006       03-03-2010, 12:00 PM Reply
Just read this and damn I feel that Tim made me a little smater. Thanks Tim for the great explanation.
