Old     (trace)      Join Date: Feb 2002       01-20-2010, 3:39 PM Reply
I'm doing a travertine countertop in a 1/2 bath, and curious what the consensus is on sealing before grouting? The grout is very similar in color to the tile, and it's tumbled tile so it's "rough" with little pockets in the surface and such. Might want the grout to smooth the surface a bit too?
Old     (zo1)      Join Date: Aug 2002       01-20-2010, 3:42 PM Reply
When we had tumbled natural stone done they did notpre seal. That said I am in the process of doing natural slate and am going to preseal cause the grout is a bit lighter than the slate. If colors are fairly close I would say don't waste the time.
Old     (trace)      Join Date: Feb 2002       01-20-2010, 4:04 PM Reply
I did slate in my upstairs bath and presealed that. I wanted it glossier and the colors to pop, but this I want duller and a more even color.
I guess my question is if presealing is generally recommended on natural stone?
Thanks for the reply.
Old     (grant_west)      Join Date: Jun 2005       01-20-2010, 4:30 PM Reply
What you wanna do if you haven't installed the stone yet you can lay it out on the ground and seal the stone.
This will make it easy for anything that gets on the stone to be removed.
If the stone is installed same thing seal it. They have lots of sealers that you can simply spray on and the stone will soak it in and you simply re apply sealer till the stone wont take anymore.
Old     (grant_west)      Join Date: Jun 2005       01-20-2010, 4:32 PM Reply
I recomend the Mira Seal 511
http://www.miraclesealants.com/
Old     (rio_sanger)      Join Date: Apr 2007       01-20-2010, 4:55 PM Reply
The 511 G recommends is the industry standard, and the best I know of.
You could also use a grout release, which is more of a temporary seal which aids in cleaning the tile or stone after grouting. They work quite well, we use these often when the client prefers not to have a permanently sealed product.
http://www.google.com/products?sourceid=navclient&rlz=1T4DMUS_enUS222US2 22&q=grout+release&um=1&ie=UTF-8&ei=yqNXS9WaHoaMswOuzamOCA&sa=X&oi=product_result _group&ct=title&resnum=3&ved=0CB8QrQQwAg
Old     (zo1)      Join Date: Aug 2002       01-20-2010, 5:05 PM Reply
Chris, Do I need to worry about the seal getting on the sides of the tile before grouting? Figuring that the grout would not adhere well to the tile.
Old     (rio_sanger)      Join Date: Apr 2007       01-20-2010, 5:31 PM Reply
Manzo ~ No, it's what the products are meant to be used for, most are water base, so it's somewhat temporary, just an aid when grouting and wiping off.
The stone eventually dries with a more natural unsealed look, if that's what you prefer.
Old     (hype29)      Join Date: Feb 2007       01-20-2010, 6:17 PM Reply
I always give it a coat after installation before grouting, then another coat a couple days after grouting to get a good seal on the grout too. Also the 511 impregnator is good, but Stonetech Bulletproof sealer is the best I have found.
Old     (zo1)      Join Date: Aug 2002       01-20-2010, 7:52 PM Reply
thanks Guys... I am going to seal after grout and before since the slate hold the grout to well if not. i was worried about the adhesion though. Good to know it wont be an issue...
Old     (hype29)      Join Date: Feb 2007       01-20-2010, 8:34 PM Reply
You especially have to seal slate before grouting. The slate will pull the moisture out of the grout too fast and the slate will also take on some of the color of the grout around the edges if not done. You can use a grout release, but sealer works fine.
Old     (trace)      Join Date: Feb 2002       01-21-2010, 5:29 AM Reply
Well, I went ahead and grouted my travertine without sealing it first. I wanted the grout to fill in the rough spots on the tile, and I like the way it came out. I will seal it after I'm all done.
I have and always would seal slate before and after.
So far:
tile
Old     (hype29)      Join Date: Feb 2007       01-21-2010, 7:40 AM Reply
Trace, looks great!! Ya it is not necessary to seal the tumbled travertine before grouting, but definitely do it after. What are you doing for your backsplash?
Old     (trace)      Join Date: Feb 2002       01-21-2010, 8:39 AM Reply
Thanks! Backsplash will be the same tile but 4x4 instead of 6x6. You can see a couple of them on the left of the pic. I'm doing the floor in the same material too, but probably 16x16 on the diagonal. Nasty old honey oak cabinets will be painted too. :-)
Old     (guido)      Join Date: Jul 2002       01-21-2010, 10:40 AM Reply
Looks great. I like that tile alot.
