Old                07-31-2003, 11:41 AM Reply
Besides just trying them over and over until you get the feel of it... Does anyone have some good advice on learning to hit double-ups?
> When do I start the cut?
> Should I start by trying to hit the 1st? Then once I'm consistent, go after the 2nd and 3rd??
> Is the pop night and day different? Do you hit it any differently than regular?
Advice?
Thanks!
Old    Thomas Deneka (tdeneka)      Join Date: Aug 2002       08-01-2003, 8:26 AM Reply
I start to drift in when the boat hits the rollers. I watch the roller that I want to hit and gradually build edge as it gets closer; I don't really look at the peak of the DU until it is right in front of me. If you aim for the peak too far out, it is easy to miss it (hit the back of it and not get up). The pop is different because it is A LOT more up than out, in my experience. It might be worth hitting a few with a little cut first, you don't have to cut very hard to get pretty high. After you get the timing down add speed/edge and you'll get way up there!!
Old    Small Light (stephan)      Join Date: Nov 2002       08-08-2003, 10:34 AM Reply
For learning you want to take it slow and not cut too far out. Basically I would not even bother with the first roller, I always attack the third one. I think about getting in the trough in front of the roller you want to hit and just follow it up to the peak, it will boot you higher but it's better to give it a hard pop and learn to use it then trying to weaken the kick. Then once you've hit it a few times, charge it and bust huge into the flats theres nothing finer. try a big poked indy or method, tantrums are a good first invert, I like to do nose grabbed back rolls they're fun.
Old    Paul (gherk)      Join Date: Aug 2001       08-08-2003, 11:26 AM Reply
Make sure you are in the valley of the rollers before you hit the wake. If you are in the valley, you will see the double up form in front of you just as you hit the wake.
Old    Matt VdA (mvda)      Join Date: Dec 2002       08-08-2003, 12:27 PM Reply
Paul is right. I usually start cutting up the trough after the 2nd roller and hit the peak made by the third roller.
