01-27-2010, 6:48 PM
Has anyone looked at which tricks cause the most injuries and what the main factors are in each? I tore an ACL on a Tantrum, probably too extended when landed.
01-27-2010, 7:05 PM
Two Concussions on Raley's One concussion on a half cab roll One Concussion on a Frontside 3. Wakeskate Injuries; Torn ACL on a Wake to Wake 3
01-27-2010, 7:14 PM
Broken foot on raley
01-27-2010, 8:05 PM
2 mild concussions from 360s. One hs fs one hs bs.
01-27-2010, 9:28 PM
Mild concussion on a TS FS 180.
01-27-2010, 9:44 PM
concussion on HS BS 360 mild concussion HS BS 180 separated rib HS FS 360 knee damage (cartilage) HS raley
01-28-2010, 6:34 AM
torn acl on whirly...shortened the rope to 75 and threw it a lil too hard and came down super hard
01-28-2010, 6:36 AM
Concussion - Hs Fs 3 (with a grab I held wayyy to long) Concussion - Hs Bs 1 Who knows how much head damage I've caused with my backroll attempts Finally... Torn Acl on Ts Frontroll, which im currently recovering from
01-28-2010, 7:37 AM
Me: ACL - Tail Glide My buddy Alex: ACL - Dum Dum
01-28-2010, 7:47 AM
ts 540 knee to the chin 26 stiches later and 4 broken teeth. wrapped kgb broken ankle bs 360 broken wrist TUBING!!! BROKEN EVERYTHING
01-28-2010, 7:50 AM
ACL/MCL tear - Whirlybird - cut a bit too hard and landed fully extended Broken Ankle - Tootsie Roll - under rotated the roll, landed on hard on my toes
01-28-2010, 7:52 AM
Tantrum - ACL Landed too extended in the flats Tantrum - ACL 2nd time, same reason.
01-28-2010, 8:02 AM
Raley - Torn MCL and meniscus HS 3 - Busted ear drum TS Jump - Broken ribs Tantrum - Tons of sprained ankles
01-28-2010, 8:55 AM
What a happy thread!! Broken Ankle - HS Front Dislocated shoulder - HS Nose 3 Separated rib - TS 5 After all these years to think that I have not been seriously concussed or really badly hurt I feel fortunate (as I feverishly knock on wood).
01-28-2010, 8:57 AM
Robot, I don't know if you can break it out trick-by-trick. I don't think particular tricks have a greater chance for particular injuries. I think it is part rider mistake and part luck. All of my major injuries were on tricks I do regularly. Indy Tantrum: ACL (Right) Toe-five: MCL (Left) Toe-Seven: Fractured shoulder (on my free hand. Not the one attached to the handle.) On an interesting note, the only times I have hurt my knees was when my stance was greater than 26. Through trial and error I have found that my ideal stance is 24-25. The broken shoulder was a fluke.
01-28-2010, 10:43 AM
Raley (off axis, tried to force the landing, and came down hard on my left leg): I had the Unhappy Triad + 2 which is a torn acl, pcl, mcl + meniscus and patella tendon TS FS 180 (awkard landing in general): Broke three metatarsals in my right foot
01-28-2010, 10:55 AM
Oh man, I didn't know we were counting busted ear drums. I've had around 4 of those on everything.
01-28-2010, 11:07 AM
Torn bycep from wrapped 3 broken ankle from HS 1
01-28-2010, 11:14 AM
http://www.live2kite.com/capix-wake-cap-p-175.html = safe eardrums. I rode with that model of helmet all last year. Had no problems adjusting to riding with a helmet. I would highly recommend this model of helmet because of the ear protection.
01-28-2010, 11:16 AM
Raley - Concussion X's 2 Hoochie - Broken Ankle Indy Tanny to B - Concussion Nose Crow Mobe - Dislocated Shoulder Jibbing - 18 Stitches Left Leg Kicker BS 7 - Concussion Jibbing a Gap - 2 broken fingers right hand (pinky & middle) Dub BS 7 - Separated 2 Ribs Jibbing in 1 foot of water - Broken Collar Bone (right) Man I have a bunch more but they are not as serious things like jammed fingers, High ankle sprains, blow ear drums, etc. I got two more concussions too for a total of 6. Unfortunately getting smack around from time to time and the wakeboarding winning is sort of the nature of the beast. Remember just because it hurt(s), doesn’t mean it should scare you. Try and Try again! Eventually you ride away!
01-28-2010, 11:27 AM
Tootsie roll- Ruptured Ear Drum (scariest because I went deaf for 10 minutes) Pete rose- torn medial meniscus on Right Nuclear glide (kicker)- torn medial meniscus on left Method Scarecrow (LOL)- dislocated rib (most acutely painful out of all injuries so far) FS Shovit to split- grade 2 ankle sprain (2nd most painful and last time wakeskating) Roof top rail transfer back lip to back lip- kidney and spleen hematoma Indy Glide- concussion Batwing- PARTIAL rotator cuff tear (thank God) (Message edited by lfxstar on January 28, 2010)
01-28-2010, 11:48 AM
WOW these are good, I think Andy leads the head trauma list. The 26 stitches and 4 teeth sounds nasty too!!
01-28-2010, 11:54 AM
"On an interesting note, the only times I have hurt my knees was when my stance was greater than 26. Through trial and error I have found that my ideal stance is 24-25." This is a good point. My knee injuries were when I was riding larger boards (141 and 142) when I normally ride a 136 or 138. I love the extra pop on the bigger boards but at 5'7, a 140 really should be my max length because of my knee problems. I know I know the landings are softer on big boards, but that isn't the issue. Because the stance is a little to wide for what I really should be riding at height wise, the wrong kind of fall really can do the trick. When I tore my left medial meniscus off the kicker, I was on a 142 and I cut as hard as I could from as far as I could to just make the kicker but accidently landed FLAT. My left knee buckled and I knew the damage was done immediately. This was also the first time I was riding a flex board which I think had 90% to do with the injury. Instead of a normal board landing flat where the nose and tail are not going to flex and flatten to the contour of the water, the flex board did just that making the impact that much more intensified. I will never do any sort of big glide or spin off of a kicker again with a raley edge on a flex board again, EVER. I have landed exactly like this probably 20 times on normal boards and never had I had that sensation before with the board hitting the water how it did. It was like slow motion coming down thinking "oh sh*t here comes a really flat landing, my knees are going to hate me tomorrow" except when I hit, I didn't move lol. On normal boards, I generally ride away from those flat landings or get pulled over the front but not this time.
01-28-2010, 12:13 PM
Wakemikey, haha he is leading FOR SURE with the head traumas. I just went to add another concussion but it was past the 10 minute posting rule. The day I learned Raleys, which was at OWC in 02 I think, I came home with a raley in my bag and a nice concussion. I remember the instructor telling me "JUST KEEP YOUR EYES ON THE TOWER, NOTHING ELSE, DO NOT MOVE YOUR EYES FROM THE TOWER". So the first couple of tries, I edged in and when I hit the wake tried to look at the tower but it just wasn't working. I was doing those backrollish falls people take when learning raleys one after another. So finally I said to myself "Ok Kyle, do not take your eyes off the tower, even when you are edging, just dont take your eyes off the tower, you dont need to look at the wake, it isn't going to move" and i did just that. I took a full raley edge, staring directly at the tower, hit the wake and what do you know, I am in a perfect laid out raley, and thats how i landed, in a perfect laid out raley LOL. The rest of the story is hearsay from my dad who was in the boat. He comes back around, im all dazed but stoked and goes, "ok kyle, do the same thing except when you feel your legs all the way out, try to break the rope over your knee like you would break a board". So I come in again, flying like a bat out of hell, staring at the tower, lay out a perfect raley, break the board over my knee and boom, stuck it that try. Took 5 tries to hit my first raley and I don't believe I've fallen on one since. My dad said I was really hungry and made him take me to the burger king to celebrate. I'm pretty sure my dad said the guy had an australian accent so it must have been Glenn Fletcher. We didn't goto the hospital because I wasn't throwing up or anything but I was definitely loopy for a couple of days. To this day whenever I teach a kid how to do a raley, I say the same exact thing, "stare at the tower the whole time, even when you are cutting and when you feel your legs are out, try to break a board on your knee with the rope" and it works every time. I have a feeling Glenn told me to do that before the whole just stare at the tower thing, but i obviously didnt do it hahahaha. *edit* i just comfirmed it was in 02 because I was riding the 02 subjekt 132. Damn that was an awesome board. (Message edited by lfxstar on January 28, 2010)
01-28-2010, 2:38 PM
Can you avoid concussions completely by wearing a helmet? Have any of y'all gotten one while wearing a helmet?
01-28-2010, 2:46 PM
Well I dont want to open a can of worms here, but 4 of my 6 concussions I had a helmet on.
01-28-2010, 3:30 PM
yeah 1 out of 2 i was wearing one.
01-28-2010, 6:07 PM
I've bashed my face hard enough both eyelids were flipped over and face was all tingly. I know I would have been concussed without the helmet. I think I have a vid of it on youtube....I'll try to find the link. Not saying the helmet is perfect but it could have been worse.
01-28-2010, 6:24 PM
torn acl on a tantrum back in 07. besides a few hard spills thats ab it for me. Used to race motocross till i broke my neck so I took up wakeboarding thinking it was a painless sport......ha ha! yea right!!!
01-28-2010, 7:33 PM
Fractured growthplate in right knee 4 times all on heelside nosegrab 180 into the flats, every time i didnt land on my edge and fell back pretty much snapping my knee. This year went back to bone and joint therapy and turned out the fractured growthplates gave me a floating kneecap.
01-29-2010, 7:20 AM
Hello all, I am sorry to hear about the injuries. Kinda supprising what a little water can do to you...I know I do this just about everytime this topic comes up, but I reaaaaally want to amass as much data as possible for a legitament medical study. Im in my second semester of med. school and the more I am learning about anatomy and physiology, the more I am intriqued by injuries related to my favorite activity....other than studying... Heres the same info again, please help us out! If you have already, thank you very much, we have gotten some good information. Shred On. http://spreadsheets.google.com/viewform?formkey=dHZiV1RLbUNIMU1zeHFJTXFjeG9Wamc6M A "So I have been talking with an Orthopedic Physician out of Chattanooga and he is going to be working on an article examining Wakeboarding-Related injuries. With my interest in both medicine and boardsports, I feel a natural draw to this topic and will be assisting him in collecting information and organizing a real medical article to be published in a medical journal. We need people who have been injured in the past (directly from wakeboarding) that would be willing to share their story so that we can study the common mechanism of injuries and shed light into what specifically can make our beloved sport so dangerous. This is really cool, as there have been very few medical/scientific explorations of question of 'why/how' injuries such as ligament tears / sprains / fractures occur during wakeboarding. Specifically, if you have ever had such a major injury (faceplants/diggers dont really count...), this would be a great chance to use the unfortunate experience to help grow the understanding of such injuries from a medical perspective, and hopefully lead to better preventative measures....who wouldnt want that. I would be happy to share more information upon request. Please contact me if you have ever had such an injury from wakeboarding or if you know someone who has. Basically, we have a questionaire you can fill it out and it would help us, science, wakeboarding, and life in general.... Spread the word, this could open the door for better health and longer sets..." -Justin Jenkins, OMS-I LMU-DCOM Justin.Jenkins@lmunet.edu (865) 237-3362
01-29-2010, 8:10 AM
here's the vid of when my face got bashed..... no concussion, quite the headache though. http://www.youtube.com/watch?v=tA5oBHIrtow edit: I think it's around the :50 second mark (Message edited by beretta5spd on January 29, 2010)
01-29-2010, 8:33 AM
Done.
01-29-2010, 9:05 AM
this led to a really bad pulled muscle in my dads shoulder. it took like 2 months to heel. so lets go with a grabbed ollie to pulled muscle! haha i couldnt help myself. haha
01-29-2010, 9:49 AM
Last season tore a rotator cuff on a switch nose 3. Besides that a few tweaked tendons in the knees and one concussion. Concussion was learning to blind tricks. Backward moustrap can get nasty. Not too many injuries really. (knocking on wood)
01-29-2010, 12:24 PM
mild concussion on a toe 7 and many an ankle tweak on tootsie rolls.
01-29-2010, 12:43 PM
Backroll = Broken Tibia. Never thought a simple roll would break my leg.
01-29-2010, 2:40 PM
Tantrum - partially torn LCL, cracked fibula Tantrum - bruised tibia DONE WITH TANTRUMS! The straight leg landings are killer.
01-29-2010, 8:02 PM
popped my right shoulder out twice when i was learning to back roll bruised my left eye socket learning to raley just after learning my ts back roll i started to get tired and when i hit the water i scorpioned so hard i put a dent in the back of my helmet from my board hitting it.
01-29-2010, 9:18 PM
Rotator Cuff - Toeside 3 - was working on grabbing and landing wrapped, fell back on my arm while still holding the handle behind my back, damage was minor, rehab and no surgery ACL, Meniscus - Roll to Revert - on a spare board and couldn't stance out all the way (08LF boots on an 06LF board) I'm tall, so narrow stance caused me to come down straight legged and POP... Both routine tricks, only takes one time to mess yourself up.
01-29-2010, 11:10 PM
Aftermath of TS360 to arm caught in handle. The bruise spread all the way down to my wrist. http://img.photobucket.com/albums/v668/TCaz33a/004.jpg
01-30-2010, 12:43 AM
Beer got stuck in the cupholder. Roll to revert on my toeside. Pulled a left forearm muscle. Tore my Koozie. Threw a tantrum!!!!! It was a bad day.
01-30-2010, 5:20 AM
concussion and winded badly on raley attempt winded badly on toe back to revert countless bad falls trying hs back 3's twinged inner knee tendon on hs roll-to-revert (lucky) and best of all, scarecrow attempt, butt check thrown forward, came outta my boots, split second doing a boardless raley about 2 feet off the water and then followed by a concussion (Message edited by IrishRider92 on January 30, 2010)
01-30-2010, 7:11 AM
Tore a lower abdominal muscle/groin on a backroll. Took 6 months to heal. Now I stretch like crazy before riding.
