Old    Ryan Duckworth (ryand121)      Join Date: Feb 2007       01-12-2010, 4:05 AM Reply
What do you guys recommend? I like the new Fulton F2, but not sure if it mounts up or not. Thanks a lot.
Old    mark (marknjenn)      Join Date: Feb 2005       01-12-2010, 7:13 AM Reply
Fulton F2 is worth every penny! Mounts to 4 and 3 inch tubes.
Old     (insuranceman)      Join Date: Jun 2005       01-12-2010, 7:41 AM Reply
it will not mount up. with some fabrication you can make it work.
Old    Gregg (gregg_rossi)      Join Date: Feb 2009       01-12-2010, 9:24 AM Reply
There is a post on Mastercraft TeamTalk about what it takes to make an plate to mount it. Looks like if you know what you are doing it can be done.
Old    dhcomp (dhcomp)      Join Date: Jun 2003       01-12-2010, 10:18 AM Reply
Get the Fulton. If you aren't the Do it yourself type, take it to a trailer shop, and have them do the conversion.
I've used them a lot at tournaments, and they freaking rock. Worth the $$$ for sure.
Old    fletch (cwfletch)      Join Date: Dec 2009       01-12-2010, 10:23 AM Reply
My (non MC) trailer came with the swivel mount Fulton (cheaper model), bought the F2 but wouldn't fit either. I went with the Fulton XP15L Swivel Mount, just as smooth as the F2 and bolts right up.
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       01-12-2010, 1:09 PM Reply
I started the thread at TMC owners that has some terrific ideas from guys about how to mount it.
The MC trailers are 6 inch beams. I just ended up doing it the cheapo way and drilled holes in the frame and bolted her right up. I am not sure it really is all that much easier to raise the boat than the original fulton, but probably a little at least.
Old    Hate N Pain (hatepain)      Join Date: Aug 2006       01-12-2010, 3:28 PM Reply
My new trailer has the Fulton F2 and I love it! It's light years better than the standard Fulton jack. It's a must have if you're replacing yours.
Old    Steve Jones (steve_jones)      Join Date: Jun 2006       01-12-2010, 10:30 PM Reply
Must be timing. Ours just died too.
Old    Jerry (witness140)      Join Date: Dec 2008       01-13-2010, 9:54 AM Reply
F2 is great, until the roll pins securing the gear to upper shaft fall out, and then the handle flies across the highway.....
Had it happen twice so far. Waiting on warranty replacement, which was not a problem.
The F2 has 2 plastic wheels, which do not like to track well when repositioning trailer - especially empty. THey love to just rotate 90 degrees to direction of travel and skip along asphalt or make a nice trench in grass. With 2 wheels the trailer is also a little harder to laterally move that inch or two that you need when the truck isn't perfectly lined up with the tongue. The old single wheelers could be manipulated left and right several inches to 'fine tune' when mating to the ball.
Much sturdier than the older POS jacks, just not the be-all-end-all.
