Old    neal sharum (moomba55)      Join Date: Jan 2008       12-28-2009, 1:33 PM Reply
I noticed while under the boat the other day oil was leaking down the inside of the tire. Any idea what might be the problem? It is a boatmate trailer.
Old    Meathead (meathead65)      Join Date: Sep 2006       12-28-2009, 3:25 PM Reply
Most likely a failed inside grease or oil seal...do you have grease or oil bath hubs?
Old    TigeMike (chpthril)      Join Date: Oct 2007       12-28-2009, 5:32 PM Reply
If it's an axle with brakes, it could be brake fluid from a leaking wheel cylinder or caliper. Try washing it off with just water, if it does, it's probably brake fluid, if not, it's oil or grease.
Old    Jamie King (jnking)      Join Date: May 2004       12-28-2009, 5:48 PM Reply
Check the allen head oil fill screw on the hub assembly. I have had these back out and leak fluid on several occasions.
Old    neal sharum (moomba55)      Join Date: Jan 2008       12-30-2009, 12:47 PM Reply
thanks for everyones help. i have oil bath hubs
