12-18-2009, 10:02 AM
Weight in the back of my truck? Didnt know if anybody else has done anything similiar when winter weather hits. Looks like for the next couple days it could get a little messy on the roads. I have a 2wd chevy 1500 and I have 400lbs in steel in the back but wondered if I should add a 350lb bag in the back too...If so, could I put some RV antifreeze in it so the water doesnt freeze or will it hurt the bag or make it deteriorate or eat up the bag? Didn't know if anybody else has done that or if its even a decent solution idea...
12-18-2009, 10:04 AM
I have seen it done. Works great until it all leaks out due to abrasion and tears. Nobody ever does it twice.
12-18-2009, 10:07 AM
What about if there is a bag around it. My 700lb is inside a protective bag....maybe the 400 of steel will work, just didnt want the back end to have all the power and be slipping everywhere...I may be allright tho, drove the mustang for 11 years in the snow and ice lol..
12-18-2009, 10:12 AM
Bags of gravel, sand, or salt are cheap and can add up lbs pretty quick. They may also come in handy if you do get stuck.
12-18-2009, 10:23 AM
Yeah, I could probably buy those instead or just try with the 400lb...may stick with that first and see how it does, if not a trip to lowe's it is...lol
12-18-2009, 8:16 PM
I filled up my launch pad 440 last winter and it worked great in the back of my F350. I pumped the water out of my trash can. No abrasions or tears at all and used it for surfing during the summer.
12-18-2009, 9:51 PM
Four good winter tires make a bigger difference than ballast. And you can even stop better. Other than that go with AtTheLake's suggestion.
12-18-2009, 10:01 PM
Tire chains will make that truck stop better than any 4wd.
12-18-2009, 10:34 PM
Yea, that just doesn't sound like a good idea.
12-19-2009, 8:12 AM
I've got good tires on it, just nothing in the back end on a rear wd truck...I got the mustang to a parking lot close to my parents and walked to their house. Interstate was closed, roads were closed, power was out...I grabbed a 4 wheeler, put on my drysuit and drove it home, approx 7 miles...so many cars on the side and in ditches, crazy stuff..
12-19-2009, 12:28 PM
works but sand is so cheap. I just bought a 50lb bag for $2.50 700lbs like a big fat sack would only be like $30
12-19-2009, 8:33 PM
Yeah, just ended up bringing the truck home today, oh well, I just looked at the tires and ok, yeah, I am at the point of needing to start looking for new ones....def before the beginning of next season...I only drive it on weekends or to pull the boat so I thought the tires were still pretty good...lol...
12-24-2009, 7:39 AM
Sand and sand bags are free at your local water districts, public works departments, etc. Check your city or county public works departments for locations. You just have to fill them. Some PW departments already have them filled for the residents.
12-24-2009, 8:25 AM
I use my pop bags
12-24-2009, 8:53 AM
Not familiar with much snow driving, but if you keep your speeds down, you can reduce the tire pressure 5 pounds to aid traction. But sand is much less of a fuss. Cheers....
