Old     (talltigeguy)      Join Date: Sep 2003       11-12-2009, 1:21 PM Reply
I am looking to rerout some of my hoses on my X-45 this winter. I will need some 1 inch check valves to make it all work.
I have done some searching but have not come up with the check valves that are just right.
I am looking for some swing type check valves that have barbed fittings that can be screwed into the them.
I like the fittings from www.flexpvc.com but they do not have ends that can be screwed into. I would like to rely on glue as little as possible.
I am sure someone knows what I am referring to and can remember where they got them. Thanks in advance.
Old     (wakesurfer08)      Join Date: Sep 2008       11-12-2009, 3:51 PM Reply
The swing type that I have are made by Spears and are threaded on both ends. I believe that these are the ones MC uses.
http://www.spearsmfg.com/
Hope this helps!
Old     (chpthril)      Join Date: Oct 2007       11-12-2009, 5:49 PM Reply
Tall,
I get mine from www.plumbingsupply.com and they are cheaper on shipping then flexpvc.com. Yes, they are the slip-fit ones that require "gluing" but dont be afraid. PVC glue is more of a chemical reaction that melts the 2 pieces together and makes them one when cured.
The valves are $11.85 ea and require 2 barbed adapters (# 460-010) and they are $1.54 ea.
Old     (wake_upppp)      Join Date: Nov 2003       11-12-2009, 6:13 PM Reply
McMaster-Carr.com
Old     (talltigeguy)      Join Date: Sep 2003       11-13-2009, 7:37 AM Reply
Thanks guys! I am sure I can find what I need in one of those spots.
Old     (wakemikey)      Join Date: Mar 2008       11-13-2009, 8:32 AM Reply
http://www.plumbingsupply.com/pvccheck.html
but the brass ones from home depot for $5 work good too
(Message edited by wakemikey on November 13, 2009)
Old     (nick_in_ssp)      Join Date: Aug 2006       11-13-2009, 9:58 AM Reply
Starnursery.com search "swing check valve" $9 for a 1". They are what I use in my system and I have had no problems
Old     (talltigeguy)      Join Date: Sep 2003       11-13-2009, 10:15 AM Reply
Wakemikey, I have never seen a brass check valve for $5. Maybe $35 if you get them in the 1 inch size like I need.
Old     (jonblarc7)      Join Date: Jul 2006       11-13-2009, 10:55 AM Reply
talltigeguy
I used the ones WakeMikey is talking about but there 12 dollars not 35 or 5.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=27947-34146-M31&lpage=none
