Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 16, 2009
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-07-2009, 10:38 PM Reply
okay, so a friend and i are talking and throwing ideas back and forth. and i have a winch spot that it would be supper easy to throw a rail in at. and he has some of that stiff indoor/outdoor carpet, would that work on the top of a rail? maybe throw some skateboard wax on it to help it slide?
anyone done or tried it?
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       11-07-2009, 10:48 PM Reply
Two words.
Capret. Burn.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-07-2009, 10:51 PM Reply
would it slide alright though? not worried about carpet burn
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       11-07-2009, 10:53 PM Reply
Brave man, but It depends. It slides well at cable parks on their docks, but that is different to being pulled on it. I'd just drop the cash on some PVC at the least.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-07-2009, 11:01 PM Reply
how much is pvc? never really prices it out. i just know trex is bank. and this is the first rail ill be hitting. and the first time putting one at this spot. so idk much about it
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       11-07-2009, 11:06 PM Reply
If it was the first rail I'd just go with the Trex. It's about 60 dollars for 36 feet at a foot wide at home depot, and it's the best surface you can have. DOnt cheap out on your first rail.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-07-2009, 11:10 PM Reply
yea. know. i was thinking that to.
my friend who lives 2 hours away might come to winch since his lake is at 5 mph now due to low water levels. and he asked if he could bring a rail. and asked to post asking how well carpet would slide.
Old    Adam Van Dyke (lfadam)      Join Date: Nov 2008       11-08-2009, 12:02 AM Reply
I strongly prefer PVC to Trex, I guess Im an oddball, but if you can get PVC cheaper than trex, its a good choice too
Old    chris garvy (wakeordie)      Join Date: Aug 2009       11-08-2009, 12:07 AM Reply
trex is the best for rails dont go cheap
Old    Matt Fifer (mfifer)      Join Date: Mar 2008       11-08-2009, 8:28 AM Reply
You really don't even need to buy trex if you're trying to save money just use wood for the surface of the rail it will slide fine.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-08-2009, 9:22 AM Reply
the guy im talking about doing this with. is thinking about buying some pvc pipe and going like 6 wide on it with some gaps in between just to make sure it slides.
it was originally going to be carpet though. so thats why i posted this thred
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       11-08-2009, 4:56 PM Reply
The best surface for a rail is HDPE with cutting board texture. Total Plastics carries it in 5X9' sheets. Camfer the edges, use elevator bolts to secure it in place and you have a very durable rail that does not chew up boards. Not real expensive, but you have to cut it like wood. Get gray or another color for UV resistance.
Old    Andy Nintzel-NautiCurl Wake Shaper (andy_nintzel)      Join Date: Sep 2004       11-09-2009, 10:35 AM Reply
OUCH!
Old    Luker (xbones)      Join Date: Mar 2007       11-09-2009, 11:29 AM Reply
FRP is cheap and works fine. Like $29 a sheet at Lowes/Depot. Its what they used in Bent Felix on the Bank and the C rail.
Old    Thomas James Arballo (thomas_arballo)      Join Date: Mar 2009       11-09-2009, 11:53 AM Reply
PVC is a pain to work with...Haha Trex is the way to go for sure..
Old    gnarshredd            11-09-2009, 1:25 PM Reply
If the rail's going to be temporary, you'll be fine with just a wood surface, just make sure you get it wet first.
It won't last as long as trex or something similar, but it gets the job done fine.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-09-2009, 1:33 PM Reply
it will only be up for 1 day.
its in the SF bay so long term wont happen.
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-09-2009, 2:03 PM Reply
scratch the carpet idea. i got permission from a good friend of mine to borrow his rail. itll be a real one. thanks for the advice though guys!
Old    Andy Nintzel-NautiCurl Wake Shaper (andy_nintzel)      Join Date: Sep 2004       11-10-2009, 7:44 AM Reply
By David Christman (lfrider92) on Monday, November 09, 2009 - 1:03 pm:
That's too bad that its a real one, well not really but some of the most fun I have ever had jibbing we were just making do with what was on hand. Jon Boat gab to log, Paddle boat to Cart Return Rail, Canoe to Railroad tie. you get the point. organic jibbing rules!
Old    David Christman (lfrider92)      Join Date: Sep 2008       11-10-2009, 8:02 AM Reply
haha for sure, ive never hit a rail though. so im thinking a real surface will be a little better while learning how this works! organic jibbing later!
