Old    brentlf            07-14-2003, 4:36 PM Reply
Ive built a few wake skates that work faurly well but the one ive built out of ply wood wont hold its shape, it just goes flat. What would be my best option to hold the shape, i figure fiber glassing it or just using the resin might work, but any tip on what to do would be apreciated
Old    WAlove (masonwakerider)      Join Date: May 2003       07-15-2003, 8:46 PM Reply
i made one out of plywood and fiberglassed it i put a full sheet over the top and a couple layers of diangle strips across the bottom. Put it back in the mold after you put the fiberglass on and it hasnt hardend yet this will make sure the wood doesnt go flat before the glass hardens
Old    stallion            08-09-2003, 2:47 PM Reply
HOw much does it cost you in material to fiberglass your wood decks?-
Old    shiftywakeskate            08-09-2003, 11:46 PM Reply
i just used fiberglass resin without any matting or anything and i got a fairly large can for 12 bucks cdn. there is enough in the can to make 2 decks probably
Old     (columbiatch)      Join Date: Oct 2002       08-11-2003, 3:35 PM Reply
Mine hold just fine without fiberglass. What are you using to glue the wood together?
Old    justin_gould            08-18-2003, 7:55 PM Reply
ive been building wakeskates out of cedar strips, and using fiberglass on the top and bottom with a layer of carbon fiber on the top... they are the lightest boards you will ever use... they make flip tricks and everything easier.
Old    pg_wakeboarder            08-19-2003, 11:16 PM Reply
if you put skate griptape onto plywood will it stay on in the water? could u put the grip on then seal it on with somethin?
Old    wsfagtron            08-19-2006, 11:23 PM Reply
i guess this might sound stupid, but when you talk about this fibreglass resin, is this like a liquid that you like paint on? haha
Old    mike hillard (otiswunguy)      Join Date: Apr 2002       08-21-2006, 5:45 PM Reply
yes. nasty crap!
Old    kcw_rider            08-23-2006, 6:41 PM Reply
hey what do you guys use for jigs cause mind never work can someone give me some ideas
