Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       10-13-2009, 6:16 PM Reply
how do you install a lipstick to your integrity?
Old    Mitch (wakemitch)      Join Date: Jun 2005       10-13-2009, 11:09 PM Reply
drill two holes and counter sink on the top for each. so you will need to cut off the middle "nipple"
put them and the end of the channel. so put the front of the lipstick right were the channel ends. the gap will be good and the distance from the nose works well.
check this out http://www.wakeskating.com/forum/viewtopic.php?p=488779#488779
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       10-14-2009, 5:51 PM Reply
for lock in tricks how hard is a simple noseslide on a flatbar?
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       10-14-2009, 9:42 PM Reply
Pretty easy.
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       10-14-2009, 10:33 PM Reply
ok any tips on a nose slide?
Old    Caleb Rountree (dlwsrider)      Join Date: Apr 2007       10-14-2009, 11:00 PM Reply
slide your front foot up on the ollie, and hold it there. Put almost all your weight on that foot. slide. Success
Old    Mitch (wakemitch)      Join Date: Jun 2005       10-14-2009, 11:57 PM Reply
i need to hit flatbars more often.
i start with a wider stance on the ollie so my foot is already almost there.
also ride parallel to the rail ollie then turn and then slam your nose into the rail. dont ollie at the rail
Old    patch mahoney (wswb4lfe)      Join Date: Jan 2009       10-15-2009, 8:56 PM Reply
ok hopefully a nose slide wont be too hard
