Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 16, 2009
Old     (lanzarote_matt)      Join Date: Oct 2009       10-13-2009, 1:13 PM Reply
Hi everyone I have just bought my first wake board and bindings. Board is absence 137 Obrien and bindings are chaser hydro slide. They came as a package. Anyway they attach to the board with thumb screws but won't tighten down hard to pull the plates down on to the board.(as if the threads are too long) So they rattle on the surface of the board. Is this normal? Sorry but I am going on the water tomorrow and don't want to break my neck or legs un-necessarily. Thanks
Old     (wakemitch)      Join Date: Jun 2005       10-13-2009, 1:14 PM Reply
use washers
Old     (njskier)      Join Date: Jul 2005       10-13-2009, 1:19 PM Reply
Your bindings should fit flat against the board with no heel-toe movement.
The solution would be to get some shorter screws. Try taking your whole setup to a local hardware store so they can set you up. (Or better yet a local board shop)
(Message edited by njskier on October 13, 2009)
Old     (lanzarote_matt)      Join Date: Oct 2009       10-13-2009, 1:24 PM Reply
Thanks guys. I will do Look out for the video (crash and burn!)
Old     (wakemitch)      Join Date: Jun 2005       10-13-2009, 1:40 PM Reply
those bindings will probably always have heel and toe lift. but for the bindings to not rattle you need to add washers on top of the baseplate and below thumbscrews.
dave, i doubt he bought hydroslide bindings from a pro shop.
Old     (jasonpav)      Join Date: Dec 2008       10-13-2009, 2:03 PM Reply
as stated before, use washers
Old     (xbones)      Join Date: Mar 2007       10-13-2009, 2:21 PM Reply
Welcome to the site Matt. Where you from?
