09-07-2009, 6:05 PM
My first board was totally flat at bottom, but this time I tried to make single concave to slight double concave. It was uneasy. I have to cut stringer then sand foam. At first it was slow then I got more deeper then I wanted and so on. Geometry starts to chaning and I started to be unsure about what I am doing. Then I found some youtube video where they are shaping concave with planer so it helped a bit. Result is not perfect and even but its ok and smooth. Still learning. Now when I look at other boards I can see thing I have no idea before. stringer is masked with thin 3mm Scotch plastic masking tape and board is sealed with microballs
09-07-2009, 6:28 PM
looks awsome , need some pics on the water after you get threw
09-07-2009, 6:45 PM
09-07-2009, 6:56 PM
09-07-2009, 7:04 PM
09-07-2009, 7:13 PM
09-07-2009, 7:23 PM
09-07-2009, 7:40 PM
09-07-2009, 8:27 PM
Nice! I love the splatter effect. What are your plans for the veneer? (Message edited by surfdad on September 07, 2009)
09-08-2009, 8:39 AM
you guy's are starting to make some nice boards keep it up
09-08-2009, 9:20 AM
thats a nice one peter looks like my shape. I like .
09-08-2009, 10:57 AM
Petr , just dont vac bag it or you w1ll get resin runners and will have to sand back down .
09-08-2009, 10:59 AM
All this on a small balcony? Thanks alot. Now I have NO excuses left.
09-08-2009, 11:59 AM
Any chance you could send me the Illustrator file.... I'd like to try one but don't have a reasonable template to start from....
09-08-2009, 6:26 PM
Jeff - I just wanted to put some teak wood veneer on top because I like it's texture (but only 14" wide or so)... and becase I like to experiment as much as I can with every new board. I will try to vac-bag it but I'm not sure if it's better to put some light glass under it to glue it directly on foam? J.L., James - Oh thanx, I'm glad YOU like it! Jim - You are right. I think I will try to put some vinil tape aroud. dtw. - Yep very small room aroud.  So now is your turn, go and buy some foam you can play with Scott - Ok I will send you my template so you can enjoy all that foam fun with us
09-09-2009, 8:23 AM
I'd love to make one as well, this would be our first board, please advise what specific tools are required and any tricks of the trade? Please send me a PM with the info..
09-09-2009, 12:09 PM
I'm not sure how you guys are building these boards, but doesn't this one still need to be glassed? Or is it a foam-top? What else needs to be done before you can ride it and won't a regular foam-top just break right away?
09-09-2009, 6:12 PM
Calix - if you search older Surfdad's threads in archive you will find nearly all you need and even more. Surfdad is our shaping guru. Also look at youtube, there are tons of surboard shaping, glassing, glosscoating, sanding, fin instalation, airbrushing videos. My first board - hotwiring etc. http://www.wakeworld.com/MB/Discus/messages/559019/613683.html?1219436311 http://www.wakeworld.com/MB/Discus/messages/559019/620714.html?1220578686 I also use some info about shaping from http://www.greenlightsurfboards.com/ watch that DIY timelapse video shaping tips http://www.greenlightsurfsupply.com/shaping_tips.html pdf instructional templates http://www.greenlightsurfsupply.com/templates.html download shaping stand, glassing stand, boxyrailbands, kniefyrailbands pdf BOARD BUILDING TIPS from Foamez http://www.foamez.com/page_4.html Epoxy Board Building Guide pdf - EPS shaping, sealing, laminating (very helful) + all fin instaltion manuals http://www.foamez.com/page_2.html (Message edited by hawaj on September 09, 2009)
09-09-2009, 6:23 PM
Robert - you are right, this is just painted sealed final shape from EPS. Not foam top. Next will be instalation of finboxes, glassing, glosscating and sanding - after all that small itchy, sticky, dusty mess I can go for ride Only hope I dont glue my pants to my ass like Surfdad
09-12-2009, 3:54 PM
07-20-2010, 2:05 PM
finally time for gloss coat  ... yea its been long time
07-20-2010, 3:03 PM
Please tell us it hasn't been sitting this entire time, and in fact you have been ridin' it and now you're just catching up the thread?
What was your process for the veneer? - thx
07-20-2010, 3:17 PM
Sorry it was sitting this entire time
I glued veneer with vacu hope it will keep for a while.
First time airbrushing first time vacu bagging its a thrill
07-20-2010, 3:29 PM
Looks good Petr, I like the veneer look. Some balsa or mahogany and maybe some walnut would look cool as hell also. Hmmm ideas?
07-20-2010, 3:41 PM
Teak this time
07-20-2010, 6:27 PM
Wow, that sucks. At least you're working on it again.
I must say, this thread, along with your 1st build thread were great sources of information and inspiration for my build, so it'll be great to see this board get finished.
07-20-2010, 6:41 PM
Looks real good Petr
07-21-2010, 1:53 AM
beauty, i can't wait to have a ride
07-21-2010, 5:38 AM
The veneers add such a great look!
08-20-2010, 1:15 PM
finish line ... I am stoked!
I surf if today and it was blast, now Im going to celebrate it with few good czech beers ... yeah!
08-20-2010, 1:22 PM
2 more
yea its freaky gloss finish ... heh why not, just for fun
And because it works great with wood, otherwise I will ended with regular matt finish. I really enjoy waterdrops runing zigzag over my teak veneer when I surf
08-20-2010, 1:30 PM
holy moly I really did it!
08-22-2010, 3:08 PM
Originally Posted by scottnaz
But..... you do realize we don't belive you...... so post up some ride pics!!!
hey scott, i'm a witness, the board rides just fine
and i think that stills from the video are also on the way.
08-22-2010, 7:36 PM
Man, that really looks great! Kind of hated dulling the sheen with some wax I bet!
08-22-2010, 7:49 PM
proof
08-22-2010, 7:58 PM
yea touching that perfect shiny surface with wax was so nasty, but there is a plenty of surface for your viewing pleasure
