Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2009
Old    rob thomas (fingerstick)      Join Date: May 2009       08-19-2009, 9:50 AM Reply
I am currently running the stock 13x11.50 lh 1" 3 blade prop on my direct drive.Would I benefit from a 4 blade "wakeboard" prop and if so,which one and what size.Thank you for any input.
Old    Tim (tcmercil)      Join Date: May 2006       08-19-2009, 10:10 AM Reply
Go with the 14.25x14 - if you can....
or call OJ prop directly and they'll be able to get the best prop for your boat...
Old    Nacho (denverd1)      Join Date: May 2004       08-19-2009, 10:11 AM Reply
pry not. rule of thumb is DD:3 Vd:4. That's a pretty torquey prop ya got on there. Sounds like a reduction ratio tranny, so maybe you would...
Old    Nacho (denverd1)      Join Date: May 2004       08-19-2009, 10:12 AM Reply
don't put the XMP prop on there....
Old    Slingshot            08-19-2009, 10:20 AM Reply
Call up Acme. Best props out there! 3 blades for a DD, 4 blades for a VD. Why you may ask? 4 blades gives you more transom lift which you need for a VD because the engine is in the back. A 4 blade on a DD will create more air pockets in the water causing you to loose power. The 3 blade will cut super smooth through the water giving you better bite and more power for your hole shot. Call up Acme, tell them what boat and engine you have, and how much weight you will be putting in it. They will get you the correct prop for your boat.
1-888-661-ACME
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       08-19-2009, 10:28 AM Reply
You likely have a good prop for your boat. You can go to a 913 Acme - 13X10.5 LH. That will drop you about 100 rpm and give you better hole shot with ballast. It is a very popular prop for the older dd ski boat that are used for wakeboarding. I sell about 15 a year.
Old    Nacho (denverd1)      Join Date: May 2004       08-19-2009, 10:58 AM Reply
call Karl ^^ @ boarditup. Good dude, fellow w/w'er, knows his props.
Old    Ben (kamighazi)      Join Date: Nov 2008       08-19-2009, 12:37 PM Reply
i wouldnt reprop. I just dropped 4bills on a Acme 913. But am coming from a 4 blade 13x13.
What i would suggest is keep your blade, 3 is good for DD, but just take it to your local guy and re-pitch it. the 913 is a 10.50 pitch, this is something that a prop guy could do for about $50.
Old    Andy Nintzel-NautiCurl Wake Shaper (andy_nintzel)      Join Date: Sep 2004       08-19-2009, 1:31 PM Reply
+1 for ACME. I run a ACME 1235 its the best thing I have ever purchased for wakeboarding.
