Old    Jon Hunter (hunter660)      Join Date: Aug 2007       07-13-2009, 4:07 PM Reply
http://www.usplastic.com/catalog/variant.asp?catalog_name=USPlastic&category_name=7 513&product_id=8742&variant_id=54251
Any reason I should not use this for my ballast system? Is there something better for less?
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       07-13-2009, 4:32 PM Reply
Never seen that stuff before, but looks like it would work. Some depends on the type of pumps you are using. Aerators are more forgiving for certain types of hose.
I like the fact it is clear...something is more cool about watching the water run through the pipes.
Old    Trace (trace)      Join Date: Feb 2002       07-13-2009, 4:43 PM Reply
It won't work with Tsunami 1200 pumps, gotta have 1-1/8" for that. Otherwise looks good. Good find.
Old    Jon Hunter (hunter660)      Join Date: Aug 2007       07-13-2009, 5:19 PM Reply
http://www.usplastic.com/catalog/product.asp?catalog_name=USPlastic&category_name=3 1577&product_id=33059
They also have ball valves for under $2.
Old    TigeMike (chpthril)      Join Date: Oct 2007       07-13-2009, 5:57 PM Reply
Wont hold up to the vacuum drawn buy Impeller type pumps, but should work ok for aerators. The 1" I/D hose will work perfect with the Tsunami T800's as it will slip right over the threaded inlet and outlet.
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-13-2009, 6:40 PM Reply
I used 1" hose on my Tsunami 1200's, just heated it up with the heat gun and stretched it to fit. Used a hose clamp before it totally cooled so the grooves would set in the hose when it cooled. Works great.
I used this hose which looks very similar:
http://cgi.ebay.com/PVC-SUCTION-DISCHARGE-HOSE-1-ID-X-100_W0QQitemZ120362780021QQcmdZViewItemQQptZLH_Def aultDomain_0?hash=item1c062e4575&_trksid=p3286.c0. m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A120 5%7C293%3A1%7C294%3A50
The bend radius is a little bigger than the black factory hose.
Old    Trace (trace)      Join Date: Feb 2002       07-13-2009, 9:01 PM Reply
TigeMike, it's called suction hose and looks like it has spiral ribbing - no reason I can see it shouldn't work with impeller systems.
Most of my hose is 1-1/8" from Flow-Rite. It fits the T-1200's perfect and just a couple extra cranks on the hose clamp to fit 1" barb fittings, or you can wrap them with electrical tape before putting the hose on. $1.47/ft.
Spa-Flex is good stuff too, but more expensive. You can cement regular PVC fittings to it. The 1 1/2" in my system is Spa-Flex, and I have a little bit of 1" here & there.
Old    TigeMike (chpthril)      Join Date: Oct 2007       07-13-2009, 9:46 PM Reply
Trace,
I wont argue till I know more about it, but my gut says it wont stand up to a pump that will "suck a golf ball through a garden hose"
I've sent a request for more info to them about the hose. We will see what the response it.
IF that hose is sturdy enough, that's a damn good price, as it's a better price then I get wholesale on a hose similar to the Shields Multi-flex.
Old    Trace (trace)      Join Date: Feb 2002       07-14-2009, 7:49 AM Reply
Cool, I'm curious too.
FWIW, from a physics standpoint, vacuum pressure can never exceed -14.9 psi.
Kink resistance, durability, oil resistance, crush resistance, and minimum bend radius are also all important concerns.
Something else I like about the 1-1/8" hose is that it comes off the barb really easily when you loosen the hose clamps. I don't have any quick release fittings in my system, so to pull a sack out I have to undo 3 hose clamps.
Old    TigeMike (chpthril)      Join Date: Oct 2007       07-14-2009, 11:20 AM Reply
Here is the response from USP Corp.
"> Hello
> The reinforcement is just the PVC. There is not other material. It can withstand 28" of mercury.
> Thank you for your inquiry
> Mindy
> United States Plastic Corp
> Technical Services
> (800) 537-9724 phone
> (800) 854-5498 fax
No other reinforcing material, but she says it will handle absolute vacuum. I may see if I can get a couple feet as a sample and see for my self.
Old    Mispella (jon43)      Join Date: Aug 2003       07-14-2009, 11:42 AM Reply
I used flex pvc and glued everything it works great
flexpvc.com
Old    Nacho (denverd1)      Join Date: May 2004       07-14-2009, 1:00 PM Reply
I've used braid-reinforced tubing with for several years with good results. Aerator system but helps out on the tight bends.
Old    TigeMike (chpthril)      Join Date: Oct 2007       07-14-2009, 4:05 PM Reply
I've requested a sample piece, we'll see if I get any. If so, i'm gonna plumb it up to my mobile AC evacuator and draw a vacuum on it will resist collapsing.
