Old    Chad Fowler (chadfowler)      Join Date: Feb 2008       07-08-2009, 3:09 PM Reply
I'm looking to go on a boating trip and need an idea of my fuel range.
I have a Supra 24SSV with a 340hp motor, 52 gallon tank and a 14X18 prop (although I could switch out my prop with a 13x17).
What's an approximate mpg and fuel range I can expect?
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       07-08-2009, 3:29 PM Reply
I would say 6-8 gallons per hour of boating.
Old    Art (rallyart)      Join Date: Nov 2006       07-08-2009, 3:30 PM Reply
You might get 2.5 MPG at 3000-3500 RPM. Much less at high speed and while wakeboarding. Less if the boat is loaded. That's just based on averages for that size of inboard. An owner might give you their numbers.
Old    pete c (saceone)      Join Date: Jan 2009       07-08-2009, 3:34 PM Reply
what kind of weight are you running?
Old    Chad Fowler (chadfowler)      Join Date: Feb 2008       07-08-2009, 3:37 PM Reply
When I'm riding I run with about 2,600-3k lbs of balast depending on whether I'm boarding or surfing, but I just want to know the fuel range fairly empty and then I can decide how much I will ride based on distance between fuel stops.
