Old     (brett_busby)      Join Date: Aug 2006       07-03-2009, 9:30 AM Reply
Opinions needed;
Problem not enough sound in back of the boat, to loud inside the boat. Not changing speakers, only amps.
Currently have:
Rockford T400-2 powering a CRV12 Kicker woofer.
Planet Audio 75.4 powering (4) DB 650 polks inside and (2) 3 way combo Fusion tower speakers
I was planning to add a T600-2 to power the (2) Fusion tower speakers
The dealer suggested using a T600-4, get rid of the Planet Audio drive the woofer and inside speakers
Use the T400-2 to drive the tower speakers. Which way would go?
Old     (lakelife)      Join Date: Feb 2003       07-03-2009, 11:05 AM Reply
Why would you want to get rid of the Planet Audio, they make great products! I would suggest the following:
- T400-2 to drive tower speakers - adjust the gain until you can hear the tunes riding
- PA 75.4 to drive cabin speakers - adjust the gain until the passengers ears aren't bleeding
- pick up a monoblock, Class D sub amp to drive your sub. As far as size of amp, if you like Kicker stuff go for the ZX-300.1 or 500.1 if you have the cash
I'm sure some of the pro guys can help you out better than I can. Good luck.
(Message edited by lakelife on July 03, 2009)
Old     (brett_busby)      Join Date: Aug 2006       07-04-2009, 8:49 AM Reply
Thanks another way of looking at it. I think the T400 is pretty well match to the woofer. But same Idea I had, keep the PA and get the T600 for the tower. Another thought the dealer thought the T400 was a good amp and the T600 could be over kill.
Old     (brett_busby)      Join Date: Aug 2006       07-05-2009, 9:09 PM Reply
TTT
Old     (lakelife)      Join Date: Feb 2003       07-06-2009, 8:03 AM Reply
The T400 is a two channel amp, so even though you can bridge it for a subwoofer, it is better suited to a two channel application... i.e. tower speakers. The class D mono sub amp will be (slightly) more efficient than a Class AB amplifier, and is designed for the task. And yes, I think the T600 is overkill for the tower speakers, but that's just me. The guy on here who has 16 wetsounds speakers on his tower might disagree!
