Old     (unclejessie)      Join Date: Jan 2004       06-29-2009, 7:05 AM Reply
Have any of you had your jack stands lock up? I greesed the gearing on top but it still is really, really hard to crank. Are you supposed to greese it somewhere else?
-Uj
Old     (ironj32)      Join Date: Jan 2007       06-29-2009, 7:14 AM Reply
i spread grease on the entire pole, as well as on top gearing assemble. also, there should be a little hole close to the top of the stand (but below the gears)...pump a bunch of grease in there and you will notice a ton of improvement in the ease of raising/lowering your trailer.
Old     (unclejessie)      Join Date: Jan 2004       06-29-2009, 7:32 AM Reply
Thanks. I will try it tonight.
Old     (ironj32)      Join Date: Jan 2007       06-29-2009, 7:42 AM Reply
if you only have enough grease to do one, i would focus in squirting it in that little hole...i found the most improvement there. also, i would not try to force the stand up or down by cranking really hard...I've broken two stands doing that (this was before i knew about the grease hole).
Old     (unclejessie)      Join Date: Jan 2004       06-29-2009, 8:04 AM Reply
Once I greese it, I have to crank it all the way down and then back up a few times though, right?
I thought it was going to fail on me last night. The stand went from a little tight to almost seizing in about 3 trips to the water. My old boat's jack stand did the same thing, so instead of buying a new one, I figured there must be somewhere else to greese it. I thought the shaft, but that didn't seem right... I have a ton of greese, so i will fill up the hole you describe.
