Old    JKW (jwat142)      Join Date: Jan 2002       06-15-2003, 7:00 PM Reply
I know people on here have said that some of the Jabsco reversible ballast pumps had problems with the impeller in them or something. Well mine is starting to act up on me. It will run for like 30-60 seconds and then it stops pumping. It slowly dies down at the end and then totally stops. If I let it sit for a minute or so, it will start back up and run again for a littl while and then stop again. Does anyone know how I can fix this? Thanks.
Old    Scott Steiner (motoxer)      Join Date: May 2002       06-15-2003, 9:03 PM Reply
Sounds like it may have lost prime. When the impeller runs dry the friction can be more than the motor can overcome and the pump will stall. open the cover and squirt a shot of oil in the impeller housing(or I've used suntan oil in a pinch) and the pump should re-prime and once wetted should run continuously again.
Old    xwake            06-16-2003, 10:16 PM Reply
Justin,
FYI, watch out using Petroleum based products if your ballast system contains rubber parts. It will make it weak and eventually fail.
Just my .02
Bo
Old    skippyh2o            06-18-2003, 1:09 AM Reply
Actually jabsco installed a slightly larger impeller for their pumps. A quick fix is to contact jabsco and tell them you need the new updated impeller. This will not cause the pump to think the system is dry and "auto" shut off. It is part of the run dry protection.
www.northwestmarine-ski.com
