Old    Marc Savatsky (yeaitsmemarc)      Join Date: Jun 2003       06-15-2003, 5:21 AM Reply
Got an 033' Launch SSV and I find that the connection between the pipes adn the ballast bags continually coems undone. Any recomendations, any else expiriance this? Thanks!
-Marc
Old    matt (supraman)      Join Date: Jan 2002       06-15-2003, 7:11 AM Reply
Use silicone tape (super-thin white ribbon type stuff) around the threads before you put together the coupling. It will keep the seal. Also, it's not like tape in the traditional sense, in that you'll still be able to de-couple it without much work if needed.
Old    Marc Savatsky (yeaitsmemarc)      Join Date: Jun 2003       06-15-2003, 2:59 PM Reply
thanx Matt.. I'll try that tom
Old    BeeTL (ofwc)      Join Date: Sep 2002       06-15-2003, 4:47 PM Reply
I believe the Supra ballast systems use Flow-rite components and connectors, but still use the blue waterbed fittings to connect to the sack.
Flow-rite has a barbed fitting that pushes into the bag opening and secures with a hose clamp.
This is a much better solution, in my opinion.
https://www.flow-rite.com/store/marine2/retail/default.htm
