Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old    Brandon Gabbard (gabbard)      Join Date: Jun 2009       06-22-2009, 6:23 AM Reply
I'm normally pretty good with this stuff but it's also usually in a truck. I have 4 JL W6 10's to put in my i/o and they sound like crap under the rear seat. Any suggestions? Thanks guys.
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       06-22-2009, 8:21 AM Reply
They are probably muffled under there. Try to vent them. How do they sound with the seat cushion off?
Old    Brandon Gabbard (gabbard)      Join Date: Jun 2009       06-22-2009, 6:19 PM Reply
About the same, I'm wondering if I need to just put 2 of them on each console,and2 at the back exposed under the seat.
Old    882001 (882001)      Join Date: Nov 2003       06-22-2009, 7:32 PM Reply
pretty vague question. sound distorted? sealed ported? amp running them? hows it wired?
Old    Brandon Gabbard (gabbard)      Join Date: Jun 2009       06-23-2009, 1:56 PM Reply
using storage as box, sound distorted, and muffled, yes I have a JL 1000v2 pushing them, I had the system in my truck and decided that they would be put to better use in the boat
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       06-23-2009, 2:31 PM Reply
Brandon I have to think that the muffled sound is coming from the fact that they don't have the ability to move any air when stuffed under a seat. Many people have cut out vent holes in the seat bases to let subs breath.
Your setup should really rock, you've got some high quality components you're using.
Can you post any pictures of the setup? How are the subs orientated under the seats, are they firing up/down/side, etc..
How far is the cone area away from the seatbase?
Old    Sam (wake1823)      Join Date: Dec 2005       06-23-2009, 2:31 PM Reply
Not enough power. They will pound with 500 RMS to each one. 250 is not enough in a boat. on top of that, thsoe subs don't sound very good unless you build the box to JL specs.
your amp settings could be incorrect, or not optimal too.
Old    Johnny Neves (johnny_jr)      Join Date: Mar 2006       06-23-2009, 2:42 PM Reply
You have to get those subs in the right box, without it you will not get any better sound. also more power is better, but I think you will get a huge improvement if you just build/or have a box built for you.
Old    Brandon Gabbard (gabbard)      Join Date: Jun 2009       06-23-2009, 2:54 PM Reply
As far as power I'm fine there when its bridge it gives you 1600rms, but it does sound like a box issue, they are firing up about 2.5 inches off seat bottom and have two 6.5" holes for ports through the fiberglass
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       06-23-2009, 2:59 PM Reply
Brandon the JL 1000/1 puts out 1000 watts rms period. Well maybe like 1200 but that's it. I wish it did 1600 rms because I have one.
